Author Topic: 2001 Jackal , hole in valve cover  (Read 12959 times)
Offline greer
« on: November 16, 2015, 09:32:17 AM »
Hi Folks,
Happy to report Doug and I finally got a Moto Guzzi-- we just bought a Jackal with a salvage title.  We didn't spend much and it doesn't look like the bike is hurt at all- it's been laid down on the right side and has mild rash on the grip, driving light, and saddlebag; the footpeg bracket is slightly bent, and there's a small shallow dent in the tank, rider's knee, we wonder?  But there's a good amount of rash on the valve cover and it's left a very small hole in one spot.  We thought we'd try to mend it while we keep an eye out for a replacement.  Would you all use JB Weld?  Epoxy Putty?  Something else?  Any suggestions greatly appreciated, and thanks in advance for your patience with our questions.
Sarah
« Last Edit: November 16, 2015, 11:13:56 AM by oldbike54 »
Re: 2001 Jackal hole in valve cover
« Reply #1 on: November 16, 2015, 09:47:00 AM »
 JB Weld is a 2 part epoxy . I've used it to temporarily seal a similar hole in an airhead tappet cover . Just get the effected area really clean and allow for sufficient drying time .
« Reply #2 on: November 16, 2015, 10:12:41 AM »
Did this to a friends Goldwing. On the inside of the valve cover we took sandpaper to rough up the metal. Cut a piece of beer can, which we sanded also. Then JB welded that to the cover. Years later he still hadn't put a new valve cover on.
« Reply #3 on: November 16, 2015, 10:47:25 AM »
Thank goodness for this thread. I had no idea what a Jackal Hole was or what I'd do if one suddenly appeared. For a while I thought it might be a confused Jacksons Hole or even an off track ah-hole but due to this forum I know what to look out for.
Offline pikipiki
« Reply #4 on: November 16, 2015, 10:48:35 AM »
If you have time to buy salvage bikes like this it might be worth enrolling on a tig welding course if there's anything like that where you are (one night a week for a term?). You can probably get the tutor to help you with that valve cover make a real nice job in the workshop and get a real insight into what you might be able to repair in future. If you take to it try and pick up some secondhand welding gear....
« Reply #5 on: November 16, 2015, 10:50:58 AM »
If I were to make a temporary patch, my preference would be to put it on the outside, so if it fell off it wouldn't get into the engine.  But I think I'd weld the hole closed.  If you can't weld it yourself, it should be an inexpensive job at a shop if you clean it well before you take it there.
« Reply #6 on: November 16, 2015, 10:57:51 AM »
While JB might hold from the inside, what it if doesn't? Murphy has already visited the bike, why invite him back?  Even from the outside, say it gets hit for whatever reason and it gets inside and your first awareness are strange sounds?
« Reply #7 on: November 16, 2015, 10:59:36 AM »
I, personally, wouldn't weld it for fear of warping it. <shrug> Valve covers are available, and not too much money.
But..
Smooth on Metalset A4 is a purpose designed aluminum filled epoxy that is perfect for an application like this. Good stuff, and cheap. (Guzzi content)  :smiley:
« Reply #8 on: November 16, 2015, 11:08:22 AM »
  Clean inside and out with acetone. sand inside and out where the J.B will go. apply a small gob of J.B. to the inside
 slightly larger bthan the hole.  While that is still wet apply a larger gob to theboutside making sure the two gobs meet
 in the hole.  After it hardens, sand as needed to make less ugly.
 Done.  I will last until crashed on the same spot.
Offline Gootsz
« Reply #9 on: November 16, 2015, 11:08:41 AM »
Ebay has a few but more money than i thought. cheapest was $60 and up.
micky
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=moto+guzzi+valve+cover&_sop=16
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
Offline Gootsz
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
Offline greer
Re: 2001 Jackal , hole in valve cover
« Reply #11 on: November 17, 2015, 05:43:05 AM »
Thanks everybody!!  Already had brand new JB Weld on hand, so pretty much did exactly as Sasquatch Jim suggested, curing at the moment.  Looks lovely already, compared to that rash.
If any of you know of a decent set of used crashbars, please pass the word.
Thanks again!
Sarah
Offline greer
« Reply #12 on: November 19, 2015, 05:22:57 AM »
Any of you found a particular rattle can paint that's a fair match to the valve covers?  Just the sanded JB Weld doesn't look too bad, but some touch-up would be nice.  I googled and searched here but mostly found info about powder coat and black paint.  And just to note, ordered a sump gasket from Harper's in the morning hours and got a shipping notice by early afternoon, extra good.  Thanks again for the help.
Sarah
Offline greer
« Reply #13 on: November 21, 2015, 05:14:13 AM »
We took our valve cover into Autozone last night and matched it up with a can of VHT High Temp Engine Enamel #SP995 Cast Aluminum; went on just about perfect color-wise, but it does have a bit of metallic to it.  We're very happy with the way it turned out, and wanted to post up in case anybody else is looking for paint.
Sarah
Offline guzziownr
« Reply #14 on: November 21, 2015, 10:34:02 AM »
In payment for our sagacity we would like pictures of your bike and the repair.
Post the pics on Photobucket or some similar host and hit the picture frame ikon to post.
How about a nice parts bike for $1200?  No connection with seller:
https://norfolk.craigslist.org/mcy/5305984978.html
Offline greer
« Reply #15 on: November 23, 2015, 01:58:00 PM »
Thank you for asking!  Here are a few pictures of the bike, and this is the patched and painted valve cover:
How about that custom rear fender?  We have no idea what happened, but it's in a perfect V.  Any of you recognize it?  We'd love to know the history on this bike; it seems well cared for over all, and has a nice set of Piaa driving lights installed.  We peeled a New York inspection sticker off the front fork.  Thanks again!
Sarah
« Reply #16 on: November 23, 2015, 02:09:20 PM »
Nice fix
Enjoy :thumb:
Offline twhitaker
« Reply #17 on: November 23, 2015, 02:13:35 PM »
Nice fix.
If it hasn't happened already you might want to replace the tail lights with superbright LED's or that will be your next project.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline guzziownr
« Reply #18 on: November 23, 2015, 02:33:44 PM »
twhittaker refers to the fact that conventional bulbs melt the plastic tail light housing...
« Reply #19 on: November 23, 2015, 02:44:52 PM »
My 98 EV is still original, I think it's if the stop light jambs on that they melt.
However the Superbright LEDs would be an improvement, I use the 194 LEDs in my dash.
« Last Edit: November 23, 2015, 02:49:18 PM by Kiwi_Roy »
Offline FGO
« Reply #20 on: November 23, 2015, 03:13:40 PM »
Call Mark at Moto Guzzi Classics, he has at least a hundred of them lying around.... Humor him and you will get a great price, low ball him and he will tell you they are $800, he is a great guy!!!
Jon
Offline cookiemech
« Reply #21 on: November 23, 2015, 04:01:09 PM »
Bike looks beautiful!
Offline mtiberio
    • TiberioRacing
« Reply #22 on: November 23, 2015, 04:11:16 PM »
Sarah and Doug sound really cheap. They will fit right in here...
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #23 on: November 23, 2015, 05:12:35 PM »
True. Sometimes I have to really work at it to get him to take my money..  :smiley:
« Reply #24 on: November 23, 2015, 05:15:41 PM »
<snapping suspenders> Welcome to WildGuzzi..  :smiley:
After all, my Jackal was salvage from a wrecking yard. I bought a new used valve cover from Mark, though..  :smiley:
Oh, nice job, Sarah..
Offline greer
« Reply #25 on: November 24, 2015, 04:14:58 AM »
Thanks everybody!  Got a pm on crashbars so we'll follow up on that, and found Mark's website so we'll keep him in mind, too.
Sarah
« Reply #26 on: November 24, 2015, 04:50:31 AM »
I just looked at your pictures again'
What other bikes do you have tucked away in the garage?
As for the Jackal, that's how a motorcycle is supposed to look  :thumb:
« Last Edit: November 24, 2015, 04:53:32 AM by Kiwi_Roy »
Offline greer
« Reply #27 on: November 24, 2015, 06:11:18 AM »
Yes we have a stable full right now: I have an '08 DR650 and a '15 Ducati Scrambler; Doug has a '99 KLR250 (see the milk crate), an '08 KLR685, a '10 Bonneville T100 Black, and a '14 CB500X.  Along with the Jackal we picked up a week or so ago.  We're 53 and I reckon we aim to have owned one of everything before it's all over.  We started out on cheap Japenese bikes, then a long stretch on BMW airheads back in the day.  This is our first go round with Ducati and Moto Guzzi, having a big time so far.  We're looking to downsize though, so you all please pass the word on the KLR685 and the Bonneville.  Thanks!
Sarah
bpreynolds
« Reply #28 on: February 17, 2016, 06:43:25 AM »
Reviving this thread a bit here as Sarah and Doug just contacted me.  This is indeed my former bike.  So happy to see it found a home following my accident.  I wanted greatly to buy it back but the insurance company auctioned before I could.
Just some info, I bought the bike off the BMW marketplace board from a fellow's wife in Florida whose husband had passed on.  He kept the bike in meticulous condition.  I do think it is likely my personal favorite California of the 4 I previously owned.  Congrats Sarah and Doug.  If you ever decide to sell that thing, do contact me first  :thumb: :grin: :laugh: I just might buy it back from ya.
Offline greer
« Reply #29 on: February 17, 2016, 07:51:49 AM »
Brian,
If you take a notion to put some miles on that Griso come on down and visit the Jackal.  Thanks again!
Sarah
