Author Topic: Squealing Noise from Gearbox  (Read 16569 times)
Re: Squealing Noise from Gearbox
« Reply #30 on: November 16, 2015, 06:28:23 PM »
 The Guzzi dealer in Indiana, who was also a shoe salesman Hired a Harley trained mechanic who did my first servicing on my second Stone.  By the time I ha made the 200 miles home, my trany was whining.  I checked and the oil was low.
 I topped it up but the thing still whined but not as loud.  I had to add nearly 200cc of oil to get it right.
 I went back to the dealer and was lucky enough to watch as the IDIOT did the same to another bike.
 After draining the oil from a warm engine.  He measured out the correct amount ito a glass measuring decanter.
  He put a funnel int the trany and poured the oil into it.  He then sat the measuring decanter down and pulled the funnel
 and close the tranny.  With the funnel in the measuring decanter I watched as 200cc of oil ran off the funnel and down the sides of the decanter and pooled in the bottom.  He never checked to see if the level was correct in the bike.
  The dealer would not do anything when I showed it to him.  He just said, The transmission still works so there is no warranty problem.  It's just one of the reasons I have not bought a guzzi since.
 Oh, BTW, when I bought the bike I asked about doing my own servicing and he told me that it would void the warranty.
  That's why I took it to him for service.
« Last Edit: November 16, 2015, 06:30:50 PM by Sasquatch Jim »
« Reply #31 on: November 16, 2015, 08:25:54 PM »
If the gearbox is grossly under filled the needle rollers under the pinions will shriek in pretty short order. Pulling in the clutch will stop the input shaft rotating so it'll go quiet, the only thing spinnin' will be the pushrod and thrust bearing.
When moving the gears destroying themselves will whine.
« Reply #32 on: November 16, 2015, 10:27:50 PM »
  Yes, I noticed that.
Offline Waltr
    • Europa Macchina
« Reply #33 on: November 17, 2015, 11:02:02 AM »
When filling the transmission and diff we use a pump hooked to a clear thin hose.  Fill them up until they are about to run over.  Someone once came back and accused us of overfilling the transmission and they were told that was impossible to do if the bike is level and upright.
www.motoguzzipa.com
2012 Norge
« Reply #34 on: November 17, 2015, 11:30:16 AM »
Thanks for that, Pete..
Offline sign216
« Reply #35 on: November 17, 2015, 06:58:02 PM »
I wrote a guide on doing the transmission oil change on a pre-2013 V7.
I'm all about self-service.  It's better to do it wrong on your own, than paying someone to do it wrong.
Double click on each photo for the text.
https://www.flickr.com/photos/sign216/albums/72157626993357143
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline novaboy
    • Big land Adventure Films
« Reply #36 on: November 30, 2015, 03:05:40 PM »
Well folks,
I dropped the bike off at the dealer last week, they said it would be a couple of days before they could look at it. They called back a couple of days ago and said the clutch was out of adjustment, and it was all fixed and ready to go. Could it have been that easy? I'm going back on Wednesday to pick it up. Bike will basically be going in storage for the winter now.
« Reply #37 on: November 30, 2015, 03:27:22 PM »
No it couldn't.
Offline fred garvin
« Reply #38 on: November 30, 2015, 03:38:27 PM »
Any chance you might be able to get a ride in before storage? Would hate to have to wait till spring to see if it was the clutch adj. or if it is in the tranny itself.
« Reply #39 on: November 30, 2015, 04:48:37 PM »
They put the fluid in that they forgot.
It isn't making much noise now.
They hope it holds together long enough for it to be forgotten.
Had you checked the fluid level before returning it?
Sounds fishy.
« Last Edit: November 30, 2015, 07:29:27 PM by Wayne Orwig »
Offline novaboy
« Reply #40 on: December 01, 2015, 05:37:44 AM »
This weekend looks like it might be good enough for a ride so I'll give it a good run then and see what happens. I never checked the oil, because the manual says to leave to a Guzzi Tech. I do know the clutch did need adjustment because when it was in neutral it was creeping forward with the clutch out.
Offline old head
« Reply #41 on: December 01, 2015, 07:37:30 AM »
you might want to run a magnetic screw driver into the oil to see if you get any bits or check the color of the oil to see if it discolored.
Had the same issue, squealing tranny at about 5k miles on my Breva 1100. Mine was a bearing that failed.  Seemed like it took about 6 weeks before I got it back.
MPH caught it during service and fixed it.  I sure hated to hear that MPH is no longer a dealer, but sometimes you get to the point where it just isn't worth it anymore.
40k miles later, no problems.
Old Head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
« Reply #42 on: December 01, 2015, 07:54:48 AM »
That is NOT a clutch adjustment problem. THAT is the signs of there being too much DRAG on the transmission gears that are supposed to be floating in neutral. It is clear evidence that there was a problem inside the transmission and NOT a clutch problem.
Now I am more convinced that they lied about the fix.
« Reply #43 on: December 01, 2015, 04:53:02 PM »
That's pretty harsh. Maybe, like many Guzzi "dealers" and "mechanics" they are just totally clueless.. and think they fixed it. <shrug>
Novaboy.. you're in a bad position. It *appears* that the dealer has trashed your transmission. I don't know what your course of action should be, but just letting it slide because it is quieter now isn't it.
Offline lucky phil
« Reply #44 on: December 01, 2015, 05:13:30 PM »
May be a descriptive issue here. Some people use the term the clutch is "out" meaning disengaged. Some also say the clutch is "engaged" when they have the lever pulled,confusing it with activated i guess.
For mine engaged means, engine driving the gearbox input shaft and disengaged means its not. IE.... engaged= clutch lever not pulled (lever out) and disengaged= lever pulled (lever in)
May have been a dragging clutch, its possible. Lets hope so.
Personally if I had a doubt about the gearbox being that low in oil I would have drained and checked it myself with someone witnessing it and recorded on my phone.
Ciao
« Last Edit: December 01, 2015, 05:14:57 PM by lucky phil »
« Reply #45 on: December 01, 2015, 05:19:52 PM »
Doesn't matter.
He said it was in neutral and the bike wanted to move forward. That is happening inside the transmission and has zero to do with the clutch.
Someone has stated something wrong.....
« Last Edit: December 01, 2015, 05:20:32 PM by Wayne Orwig »
« Reply #46 on: December 01, 2015, 05:23:21 PM »
No it couldn't.
 Seems we are all in agreement .
Offline lucky phil
« Reply #47 on: December 02, 2015, 02:25:53 PM »
Doesn't matter.
True, missed the in neutral part. Just trying to be hopefull
Ciao
« Reply #48 on: December 02, 2015, 06:10:26 PM »
Ciao
Yeah, I was thinking maybe clutch adjustment until then, too.
Frulk
« Reply #49 on: December 02, 2015, 09:07:20 PM »
Sadly Novaboy, I'm in the same boat as you. Took a brand new 2014 V7R in for initial 500 mile maint. at my local MG authorized dealer where I bought it and best guess is the mechanic put about 20% of the required lubricant in the gear box. Squealing/screeching started at approx. 3600 miles. Vasco DG here diagnosed the issue perfectly. Took it back to the dealer in SLC, Utah and they supposedly spoke with Guzzi Corp HQ and were told to add fluid and see what happens. Noise was less but still there and now have 4400 miles and think it's getting a little louder. No longer riding it because of serious concerns about driveline lock up at speed on the road.
Spoke with service manager at the time I took it in around 3600 miles and they admitted their mistake. Spoke with Sales/business manager and he offered me a $50 gift card and verbal assurance should something happen they would step up and fix it. Asked for written assurance of this commitment as mechanics and sales staff and managers who knew about the issue leave but he refused.
Love the V7R and MG Brand. Despise the SLC dealership and weak customer service support via MG Corp HQ. Still pondering my next move. Pretty sure I'm done with the MG marque which is too bad because I would have been a loyal customer and had designs on a California and possibly buying a V7 for my daughter as a gift for attaining some significant educational milestones in her life.
Because of the above mentioned sub par customer experience with my Guzzi dealer my daughter is now on a brand new 2015, mildly customized HD 883 Iron, the California is out of the question, and I'm considering a new-in-the crate 2013 Honda F6B.
Frulk
« Reply #50 on: December 02, 2015, 09:39:52 PM »
It's sad that you're writing off a marque because of a poor dealer.
PJ, the DEALER is the face of the MG Marque. It's who the customer interfaces with. This isn't Chevy or Ford where there's a dealership on every main drag. This is MG, a low production, imported niche brand with a limited dealer and support network. I was willing to accept all of this based on the fact I had a dealer within 40 miles one way to work on the bike if issues arise. Since I have zero faith in my dealer now based on the fact that routine service is beyond the scope of their service department they are no longer an option. I'm not trailering the bike out of state for service. I'm loyal, but not blindly so and my loyalty has limits.
Because of some of the 'perceived' drawbacks of owning a Guzzi I mentioned above it's even MORE important for the dealers to ensure the small customer base they're trying to develop into a larger following is treated especially well. Guzzi dealers can't afford to alienate even a small part of their customer base compared to their much larger competitors.
« Last Edit: December 02, 2015, 09:47:48 PM by Frulk »
Frulk
« Reply #51 on: December 02, 2015, 10:00:45 PM »
  I don't blame Moto Guzzi if I screw up, but you blame Moto Guzzi if a dealer screws up.  My perspective is different.  I'm coming from somewhere else.  I'm happy here.
PJ, I didn't "blame" MG for the dealer screwing up. What I wrote was "Despise the SLC dealership and weak customer service support via MG Corp HQ". MG can't be oblivious to the fact that this gear case under-filling has happened on numerous occasions on new bikes stateside as I've seen it discussed on several occasions here. I don't expect MG to foot the bill to fix my bike. What I do expect from them is that they set certain standards for the dealers that fly their banner. It's in their own best interest to do this. And in especially egregious cases intercede on the customers behalf via mediation and potential dealer sanctions.
« Last Edit: December 02, 2015, 10:01:35 PM by Frulk »
Frulk
« Reply #52 on: December 02, 2015, 10:28:38 PM »
And that's one of the main reasons I'm where I'm at. The SLC, Utah MG dealership (apparently) didn't properly train their reps in front-line customer service,  their sales manager doesn't understand the concept of service recovery when his front line folks fail to meet the customers expectations, nor (it appears) was customer service built into their business model and assigned any meaningful priority.
I'd love to come down to the dealership and do a 2-hour customer service seminar and run the whole staff through my situation using a Root Cause Analysis/ flowchart approach.
What the short sighted sales manger doesn't understand is how much money he lost by not making the situation his service department caused right. Since this experience early this year I've purchased two new bikes (Honda CB1100 that should have been a Griso had this not happened and had it been in stock and my daughters HD Iron 883 that prob would have been a black V7 Stone). And then there is initial service fees etc.
« Last Edit: December 02, 2015, 11:20:58 PM by Frulk »
Frulk
« Reply #53 on: December 02, 2015, 10:37:28 PM »
This is where we started.
LOL..I feel like I just finished watching '50 First Dates'. Tell you what. When a dealer comes to Ogden I'll give them another chance. That leaves the door open.   :thumb: By then I might be over the hosing I'll take on the V7R in the meantime.
« Last Edit: December 02, 2015, 10:38:26 PM by Frulk »
LaMojo
« Reply #54 on: December 03, 2015, 08:10:54 AM »
Probably not a bearing but one of the gears that normally spins on the shaft while in neutral has galled the shaft from lack of oil and is trying to seize causing the noise and creeping.
Offline novaboy
« Reply #55 on: December 26, 2015, 06:19:10 AM »
I managed to put on about 200km since getting the bike back. There is still a noticeable whine that was never there before my service. At low rpm and closed throttle it's not there but becomes apparent at mid to high RPM. Bike also needs to be nice and warm, ridden for a few minutes before it rears it's ugly head.
Gonna call the dealer back this week, and see what they say...this time.
« Reply #56 on: December 26, 2015, 09:28:45 AM »
Sorry, but wishing and hoping aren't going to fix a buggered gearbox.
Offline novaboy
« Reply #57 on: December 26, 2015, 03:49:51 PM »
I know its buggered, just playing the game with the stealership.
