Author Topic: V9 engine?  (Read 34469 times)
Offline Dogwalker
Re: V9 engine?
« Reply #60 on: November 17, 2015, 04:52:40 PM »
But I don't see where even your days proved your point of 10%. Especially from "calculated crank".
The average loss from (measured) crank to RW of the 20 samples reported is 9.64%
I do continue to appreciate all the info you so readily provide.
My pleasure.
Thanks. :grin:
« Last Edit: November 17, 2015, 04:57:03 PM by Dogwalker »
Re: V9 engine?
« Reply #61 on: November 17, 2015, 05:01:19 PM »
But Motoclismo DIDN'T ACTUALLY MEASURE THE CRANK hp.
You said they calculated it based on their dyno runs no?
That means using some formula that is sounding very close to 10%.
Do you know HOW THEY go about it?
What tells us their calculations are accurate?
Unless you're ALSO telling me they removed each motor and performed a test at the crank???
That's why I was basing my loss numbers on the spec.
« Last Edit: November 17, 2015, 05:03:29 PM by Kev m »
Offline Dogwalker
Re: V9 engine?
« Reply #62 on: November 17, 2015, 05:26:24 PM »
It did.
The test bench is a measuring instruments like another. It estimates the loss from crank to RW from the drag of the transmission when driven in neutral. It's an estimate, like is an estimate the distance, direction and speed measured by a radar equipment.
It's measurements can only be refuted by a more accurate instrument. Not by someone saying that the measurement can be wrong.
To not like the instrument is your personal choice. But has not an objective value.
The measure of the instrument has.
That's surely worse, since, that way, you are mixing the measures of many different test bench, even in the case the specs are effectively measured, and not written as they are for other reasons.
« Last Edit: November 17, 2015, 05:33:01 PM by Dogwalker »
Re: V9 engine?
« Reply #63 on: November 17, 2015, 06:13:10 PM »
It did.
Ahhhhhhhh, ok, I'm sorry. I missed the explanation on the crank estimation.
So the difference in my estimations and yours is that mine don't take into account the variance in individual builds from OEM spec. And it is THAT variation that is allowing the loss calculation to vary from 10-18% which is an error in my data.
I see your point and have to concede then that I'm wrong.
Assuming the Motoclismo crank estimation is accurate (and I can accept that), then I can't argue anymore.
Thanks for the patience. I get it.
« Last Edit: November 17, 2015, 06:14:59 PM by Kev m »
Re: V9 engine?
« Reply #64 on: November 17, 2015, 06:15:21 PM »
 We need a lightbulb emo  :laugh:
Re: V9 engine?
« Reply #65 on: November 17, 2015, 06:22:24 PM »
A BIG ONE!  :embarrassed:
Re: V9 engine?
« Reply #66 on: November 17, 2015, 06:23:41 PM »
He can be a little slow.. but he's part of the family..  :smiley: <running and ducking>
Re: V9 engine?
« Reply #67 on: November 17, 2015, 06:28:05 PM »
Wait, you talking about ME or my BIKE?
... WAIT... BOTH????  :thewife:
Re: V9 engine?
« Reply #68 on: November 17, 2015, 06:28:29 PM »
 Fortunately for me that "family" thing is true  :rolleyes:
 It was a very productive conversation , and not bad to admit we don't know it all  :thumb:
Offline Dogwalker
Re: V9 engine?
« Reply #69 on: November 17, 2015, 06:32:46 PM »
Obviously it will be even better to remove each motor and perform a test at the crank. That will be a "more accuate instrument".
But, by the fact that, in many cases, the bench of the magazine obtained results that are very similar to the specs, so two different instruments indipendently obtained the same result, I can think is pretty accurate.
Nothing! :grin:
