Author Topic: T3 speedometer & Tach on Eldo  (Read 2530 times)
Offline Guzzer
  • Retired
« on: November 24, 2015, 08:53:04 AM »
Can I put a speedometer & Tach from a T3 on an Eldorado?  Same cables, etc?
1970 Moto Guzzi Ambassador riding refurbishment
1971 Moto Guzzi Ambassador
Moto Guzzi T waiting for some attention
Moto Guzzi 850 T3 for trips
Suzuki GS550 for easy country  riding
Re: T3 speedometer & Tach on Eldo
« Reply #1 on: November 24, 2015, 09:44:45 AM »
Is the T3 tach electronic like the Eldo?
I think the speedo is probably the standard 1000 revs per mile
« Reply #2 on: November 24, 2015, 11:34:08 AM »
The T3 tach is cable driven, not electronic like the Ambo/Eldo unit, so unless you used the Tonti timing cover and cam, it wouldn't work. Using that timing cover opens another can of worms...
Offline Guzzer
  • Retired
« Reply #3 on: November 24, 2015, 11:45:41 AM »
I have plenty of cans of worms already open so I'll forget about adding another!
Thanks guys!
Offline NCAmother
« Reply #4 on: November 24, 2015, 11:46:38 AM »
aftermarket tachs and speedometers run electronically and sometimes use GPS, if this is an option
Howdy
« Reply #5 on: November 24, 2015, 12:13:27 PM »
While we're on the subject, anyone need a Veglia electronic tach for a 6 cyl. engine? Looks just like an Ambo/Eldo tach except there's no redline marked. 80 mm diameter.
Offline guzziownr
« Reply #6 on: November 24, 2015, 02:36:50 PM »
The blue faced tach from the later Cal II was electronic, says so on the face, but it is "one pulse" (I made that up!).  For every revolution of the engine the coil it is attached to fires once.  The Eldo coil fires twice per revolution so the attached tach I would dub "two pulse".  If you gave that six cylinder tach to a speedo shop they could alter it to suit.  I know this because I am running an altered Eldo tach on an SP motor.
I like the look of the blue faces.
