Author Topic: Guzzi LM2 / CX100 Fuse Box Diagram & No Starter  (Read 3322 times)
Wazfromoz
« on: November 27, 2015, 10:09:48 PM »
Hi, Does anyone have diagram of the function of each of the fuses ( top to bottom ) of each fuse in the main fuse box of a 1980 LM2 /CX100 ? I have looked at the circuit diagram, but am not smart enough to   understand what each fuse does. I have no juice to the starter motor and it isn't the relay that lives under the fuse box, so am trying to backtrack. The fuses are all intact. Tks, Waz
« Last Edit: November 28, 2015, 06:23:23 AM by guzzisteve »
Offline Stevex
Re: Guzzi LM2 / CX100 Fuse Box Diagram & No Starter
« Reply #2 on: November 28, 2015, 06:30:28 AM »
Check this wiring diagram, easy to follow in colour.
http://www.thisoldtractor.com/guzzi007/pdfs/1978_LeMans_II.pdf
The fuses may be intact but check you have continuity between the two posts that hold each fuse; you may find corrosion or a poor contact.
What have you done to prove the starter relay?
« Last Edit: November 28, 2015, 06:34:22 AM by Stevex »
« Reply #3 on: November 28, 2015, 07:09:54 AM »
Yeah, switchgear. Especially if it is the original equipment.
I always add an extra wire at the starter for just those occasions when I get nothing at the start button; I can just reach down and start the bike directly at the starter.
