Author Topic: fork cap nut size UPDATE  (Read 2077 times)
Offline Gootsz
« on: December 01, 2015, 07:22:49 AM »
All
I need to know what is the size of the fork cap nut for a 2K Jackal  EV, etc. i want to but the exact socket not just whatever i have that fits.
Thanks in advance.
Micky
« Last Edit: December 02, 2015, 09:52:15 AM by Gootsz »
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: fork cap nut size
« Reply #1 on: December 01, 2015, 11:17:10 AM »
I would measure it in case your model is different to others.
Also, you should consider whether you can fit a socket on without removing the handlebars.  I think I've had to use a large flat ring spanner for this reason.
Offline Gootsz
« Reply #2 on: December 01, 2015, 11:29:34 AM »
Dave
Understand. i am at work and forgot to measure. i wanted to get a socket on my way home. It will fit (barley without taking the bars of)f if i remember correctly
micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
Online pehayes
« Reply #3 on: December 01, 2015, 12:27:49 PM »
On my 98EV, the hex top is 36mm.  However, the 98 has adjustable damping and that might not be the case with your model.  Also, by visual inspection, I seriously doubt there is adequate room to fit the socket wall around the hex with the handlebar in place.  Take a chance and buy the 36.  Just be sure you can take it back and exchange it if you find your size is different.
« Last Edit: December 01, 2015, 12:28:24 PM by pehayes »
Offline Gootsz
Re: fork cap nut size UPDATE
« Reply #4 on: December 02, 2015, 09:58:59 AM »
BUMP
The Hex nut (Fork Cap nut) for a 2000 jackal non adjustable forks are 30mm. And yeas a socket does fit.
micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
