Author Topic: Impact damage on piston skirt  (Read 3122 times)
Offline Capt.Lloyd
« on: December 07, 2015, 10:30:57 PM »
Hello everyone, Capt.LLoyd from Victoria B.C. here.  I'm the happy owner of a 72' Eldo currently being dismantled on the way to restoration.  My curiousity is this:  studying the right hand side piston the other night I see an impact ding along with a small and short crack on the upper skirt bottom.  Is this something that anyone has seen before?  I hesitate to guess what might have caused it...any ideas?  Also, would the concensus be that the piston is junk?  The 'ding' is from the outside surface facing inward, the wear pattern on the surrounding skirt shows no high spots.  Dimension of ding: perhaps 1/4" in length,  1/16" depth.  It's running vertically from the skirt bottom towards the crown.  I'm looking forward to your thoughts everybody, thanks.  I'll post some snaps tomorrow...
Cheers, Capt.LLoyd AKA Paul Jones
Re: Impact damage on piston skirt
« Reply #1 on: December 07, 2015, 11:20:13 PM »
You're going to install Giladoni kits, right?
So those old pistons are history.
« Reply #2 on: December 07, 2015, 11:38:47 PM »
and short crack
Crack, yes, junk.
Well, there is JB Weld.....  :boozing:
Pretty odd.
« Reply #3 on: December 08, 2015, 07:03:53 AM »
I've seen this type of damage come from an engine being turned  with the jug off and the piston unsupported catches on the block . Means the piston has reached the end of its service life.    :sad:
Offline yogidozer
« Reply #4 on: December 08, 2015, 07:11:29 AM »
possibly dropped by PO when dismantled on another tear down?
George_S
« Reply #5 on: December 08, 2015, 09:01:32 AM »
If I'm understanding correctly what's being described, I think I saw this once caused by a ring failure. Is there a chip in one of the rings?
Offline Capt.Lloyd
« Reply #6 on: December 08, 2015, 10:05:16 AM »
I think it's time to price out new cylinders and pistons...unless someone here has a functional set sitting on a shelf
Thanks for the feedback,
Paul
« Reply #7 on: December 08, 2015, 10:10:27 AM »
Paul
If you have the original cylinders with chrome plated bores, then it is definitely time to source replacement cylinder kits.
« Reply #8 on: December 08, 2015, 10:24:48 AM »
There is no such thing as a 'Functional Set' of forty plus year old chrome plated bores. Their failure is not a case of *If*, it's a case of *When* and the *When* is generally sooner rather than later.
Offline NCAmother
« Reply #9 on: December 08, 2015, 10:38:39 AM »
does the crack end at the piston pin area?
Howdy
