Author Topic: Engine oil removal using suction through the dipstick tube.  (Read 7917 times)
Offline Stevex
« on: December 08, 2015, 12:56:22 PM »
Yes, really.
My wife has a Smart car and the engine has no sump plug.
The only way to carry out a oil change is to suck the oil out using a small bore plastic pipe going down the dipstick tube.
Last time I had it done by a local garage as I don't have a manual suction pump.
Problem is the reviews of available suction pumps aren't too good, so I'm wondering if there's an alternative.
Oil grade is 5w/40; if it was warm, could it be siphoned?
Any ideas?
father guzzi obrian
Re: Engine oil removal using suction through the dipstick tube.
« Reply #1 on: December 08, 2015, 12:58:17 PM »
This is a guzzi forum, we would drill and tap a sump plug..... :evil:
Offline twhitaker
« Reply #2 on: December 08, 2015, 01:09:39 PM »
I had a dipstick pump for my boat that worked just like a syringe.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline sib
« Reply #3 on: December 08, 2015, 01:26:34 PM »
Turn the car upside-down, and let it drain out overnight.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #4 on: December 08, 2015, 01:28:18 PM »
 I have used one of these in the past.  Just suck it full of oil and squirt it into your waste container and suck some more.
 Simple and workable and cleanable.
 http://www.tooltopia.com/lincoln-lubrication-615.aspx?utm_source=google&utm_medium=cpc&utm_campaign=paid_search_google_pla&scid=scplp6819959&gclid=Cj0KEQiAnJqzBRCW0rGWnKnckOIBEiQA6qDBarSNlQODOlewD2S_Ajcq3vykHATpZl2ZtlZE6rpS17saAsQz8P8HAQ
« Last Edit: December 08, 2015, 01:29:05 PM by Sasquatch Jim »
Offline pyoungbl
« Reply #5 on: December 08, 2015, 01:28:54 PM »
This is pretty common on boats, where you cannot get to the sump drain.  I got mine from West Marine but here's a link to one on Amazon:
http://www.amazon.com/Briggs-Stratton-5431K-Extractor-4-Liter/dp/B009POZ9YY/ref=sr_1_7?ie=UTF8&qid=1449602526&sr=8-7&keywords=topside+oil+changer
$34 ain't bad!
Peter Y.
'13 V7 Special (red/white)
« Reply #6 on: December 08, 2015, 02:02:38 PM »
ROFLMAO
Offline Mike Harper
    • harpermoto.com
« Reply #7 on: December 08, 2015, 02:03:57 PM »
And folks want to blast Guzzi for things they design.
What a dumbass way to build something that requires periodic maintenance.
Sheesh !!!
« Reply #8 on: December 08, 2015, 02:12:18 PM »
 Turning it upside down is not efficient.  You would have  rock it back and forth and side to side to get most of the oil out.
 Not like a motorcycle where you can just invert it and shake it.
Offline NCAmother
« Reply #9 on: December 08, 2015, 02:19:58 PM »
Yes, really.
Any ideas?
It's very interesting that a smart car that uses an oil does not have a  filter.  I change the oil not only because of mileage but to remove sludge buildup and inspect metal content.
« Last Edit: December 08, 2015, 02:21:38 PM by NCAmother »
Howdy
« Reply #10 on: December 08, 2015, 02:22:25 PM »
Sheesh !!!
They don't leak oil or lose their dipsticks.
They don't need an oil change every 6250 miles either. It really isn't a big deal. No burned hands and in fact you can do it without getting a drop if oil on your hands.
Now for an easy way if you have a compressor ( like to fill tires and stuff)
Get one of those venturi effect liquid sprayer things for the compressor. Clear tube goes into the filler hole, gun end into waste container. Compressor creates the venturi effect and sucks all the oil out in short order.
Do the opposite to fill the sump. Out the tube right into the oil container that has the proper amount of oil and fill er up.
Entire oil change takes 5 minutes and you can do it wearing nice clothes. It is clean, no waste, no rags, getting on your back, grabbing wrenches.
In between drain and fill, spin off old filter, spin on new one. Then onward for another year instead of every 3 months.
« Reply #11 on: December 08, 2015, 02:43:54 PM »
It has a filter, just no drain plug.
« Reply #12 on: December 08, 2015, 02:48:54 PM »
Liquivac.  Affordable.
http://www.liquivac.com/
« Reply #13 on: December 08, 2015, 02:51:14 PM »
Sheesh !!!
Having not seen the powertrain I'm going to assume it's because you can't get to it easily enough.
But as has been said it's commonplace in the marine industry because most inboards and sterndrives are mounted in such a way that you can't access the sump (since they're in the bottom of the hulls).
And I'm noting that in the last few years Yamaha has adopted this as the recommended method for most/all of their outboards too. And I'm not just talking about little $5k ones, I'm talking about the $30k ones often sold in pairs.
So dumb design? Depends on the perspective, but it certainly seems to be a viable method.
Steve, what about stopping by a marine supply store, they should be familiar with some decent design pumps.
Offline Cross-tie Walker
« Reply #14 on: December 08, 2015, 02:53:07 PM »
I see Liqiuvac is only for "Harleys"
Kevin in Seattle
'72 Eldo
'07 Vintage
Offline Markcarovilli
« Reply #15 on: December 08, 2015, 02:56:36 PM »
or it is one of the new designed permanently lube engines..... :rolleyes:
Mark
Offline stick
  • Greater Worcester, MA
« Reply #16 on: December 08, 2015, 03:13:11 PM »
Ah, just change the filter and add a quart...
It's a smart car, right?  It'll figure it out.
Stick
Nothing like stuffing a Goose between your legs
2013 Stelvio NTX
2002 V1100 Lemans
1996 Sport 1100
2003 Ducati ST4s
« Reply #17 on: December 08, 2015, 04:23:57 PM »
I've been vacuum draining several of my vehicles for years. I had wondered how Mercedes was doing oil changes on my ML55 so quickly back when it was under warranty and my service manager told me about it. The filter's right up there on top too so it's a quick turnover.
I use a medical hand operated vacuum pump and even though I have to empty the reservoir twice in the process - it keeps me from dickin' with the belly pans.
Since then: Guzzis, Mini, and even my Cub Cadet. I'd use it on my Scout, alas, it has dual sumps.
Todd.
Offline Stevex
« Reply #18 on: December 08, 2015, 04:28:16 PM »
Thanks for all the suggestions, I'm going with Jim's, suction gun on order.
Offline boatdetective
« Reply #19 on: December 08, 2015, 04:54:01 PM »
http://www.jamestowndistributors.com/userportal/show_product.do?pid=9547&familyName=Moeller+Fluid+Extractor+Pumps
That's the only way to change oil on marine engines. These hand vacuum pumps work PISSAH.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
Offline weevee
« Reply #20 on: December 08, 2015, 05:24:05 PM »
I have a Smart car, and use a Pela 6000 extractor pump.  http://www.mailspeedmarine.com/oil-extractor-pump-37774.html?gclid=CP3q4pyuzckCFQ-3GwoddjIHZg  It's brilliant.  The oil can be changed in minutes with no mess whatsoever - and there's no makeshift drain-tray full of krud to then have to deal with.  In truth it's one of the best gadgets I've ever bought.  (..it was once a real help in removing oil from an over-filled Guzzi sump!)
« Reply #21 on: December 08, 2015, 05:24:33 PM »
It's not only the simplest but you can squirt waste oil at people too.
Offline normzone
« Reply #22 on: December 08, 2015, 05:51:59 PM »
I'm all for this approach. The logic is sound...
Offline rboe
« Reply #23 on: December 08, 2015, 06:41:23 PM »
Just replace the car. New ones come with new oil already in them. http://wildguzzi.com/forum/Smileys/default/boozing.gif
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
« Reply #24 on: December 08, 2015, 06:52:06 PM »
Stick the hose down through the dipstick hole and suck.  I guess they figure that it's a bigger market for HD's than any other market.  I bought my from Home Depot out here.
Offline jbhotchkiss
« Reply #25 on: December 09, 2015, 01:07:50 PM »
Might this work for fork oil as well?  What a pain it is to have to remove the fork tubes to drain the oil.
Offline mtiberio
    • TiberioRacing
« Reply #26 on: December 09, 2015, 01:16:22 PM »
Sheesh !!!
I smell a business opportunity, Harpers Outsider remote external sump drain for smart cars.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #27 on: December 09, 2015, 03:18:49 PM »
Depends on how the forks are built. I used to drill a bike at the bottom ala older Hondas and just drain them. Seemed the easiest way. Unscrew the bolt, pump the forks and all the oil shoots out, literally.
Make sure you have something to catch the oil, it will shoot clear across most of the garage floor is you don't.
elvisboy77
« Reply #28 on: December 10, 2015, 05:30:48 AM »
I just spit coffee all over my work clothes.  Thanks for the laughs!
« Reply #29 on: December 10, 2015, 06:16:36 AM »
Get a REAL gas guzzling CAR?
