Author Topic: What's it take to do the Norge clutch slave?  (Read 1522 times)
Offline ITSec
« on: December 08, 2015, 01:44:41 PM »
My Norge has apparently developed a leak at or near the clutch slave cylinder - very annoying in a bike that has a mere 100,000 miles (can't they do better?  :wink: )
Some of the threads have been archived off, so a recent search on this topic didn't give me a lot of clear info. From what I can find, I'll need to remove the shock and swingarm to get at the dang thing - is there anything else I should know?
For those who've done this, is it usually the slave unit itself that leaks, or are the lines a problem? What parts should I be prepared to obtain?
Ah well, I can console myself with the thought that it's time to send the Hyperpro shock in for a rebuild anyway... fortunately, I have the factory unit as a spare (new warranty replacement unit).
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Re: What's it take to do the Norge clutch slave?
« Reply #1 on: December 08, 2015, 01:53:47 PM »
Need nothing but the o-ring thats on it.  Tools are Clutch hub nut tool for swingarm and a 14mm allen for swingarm pin.
« Reply #2 on: December 08, 2015, 02:24:34 PM »
That's it basically. You don't *have* to remove the shock but it makes access easier.
Is it hydraulic fluid or gear oil? If the former it's probably a leaking sealing washer or slightly loose banjo on the slave if the latter, (Far more likely.) as Steve says the only thing you should need is a new o-ring.
Re-pack the swingarm bearings and linkage bearings while yer'rs in there.
Offline stick
  • Greater Worcester, MA
« Reply #3 on: December 08, 2015, 02:55:38 PM »
a small member...       couldn't resist!!!!!!!! :grin:
Stick
Nothing like stuffing a Goose between your legs
2013 Stelvio NTX
2002 V1100 Lemans
1996 Sport 1100
2003 Ducati ST4s
