Author Topic: Guzzi's Three Wheeler - I haven't seen this before...  (Read 12917 times)
Offline wymple
Re: Guzzi's Three Wheeler - I haven't seen this before...
« Reply #1 on: December 10, 2015, 07:16:46 AM »
where you been.. they were built in the 1960's
« Last Edit: December 10, 2015, 07:17:48 AM by fotoguzzi »
Offline steven c
« Reply #2 on: December 10, 2015, 10:34:10 AM »
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline pehayes
« Reply #3 on: December 10, 2015, 10:41:43 AM »
This Mechanical Mule is very important in Guzzi history.  Until this model (and except for a few exotic race versions) all Guzzi motors were single cylinder.  This machine introduced the 90 degree V-twin to regular Guzzi production.  That primitive motor went on to become the power plant we all now love and enjoy.
« Reply #4 on: December 10, 2015, 11:01:10 AM »
merged.
« Reply #5 on: December 10, 2015, 11:04:04 AM »
« Reply #6 on: December 10, 2015, 11:16:39 AM »
Actually 3 wheeled utility, truck vehicles were all over Europe and even Japan in earlier times.  I  have a slide of a 3w/dump truck in Japan in `68.  In Italy they are called Apes(ahpees).
« Last Edit: December 10, 2015, 11:18:08 AM by Arizona Wayne »
« Reply #7 on: December 10, 2015, 11:20:58 AM »
I have to disagree with this statement. Greg Field effectively dispels this myth in his book "Moto Guzzi Big Twins".
Individually, Carcano and Todero had each worked on 90-degree Vs in the past. Carcano had designed an air-cooled 600 cc engine designed to power the Fiat 500 car, and Todero had helped develop the fan-cooled 750 cc engine for the 3x3 Mechanical Mule, an engine designed by another Moto Guzzi engineer, Antonio Micucci.
Neither the Fiat 500 nore the Mule engine was used as the basis for the V700 engine, however, and it's somewhat puzzling how the whole misconception got started, given the fact that the Mule engine was designed by Micucci, rather than Carcano. The fact is, all the V700 engine and the other two share in common is a 90-degree V-angle. "Comparing the head design and structure, the distribution, displacement, lube and fuel systems and engine crankcases is enough to demonstrate that the engines are totally different and come from different ideas, " asserted Todero. Said Carcano on the issue: "The (Mule) engine has nothing in common with the V7. It had a forced cooling system and was a 90-degree V, but it's cylinders, heads, and engine casing, etc., differed completely.
« Last Edit: December 10, 2015, 11:29:08 AM by Antietam Classic Cycle »
« Reply #8 on: December 10, 2015, 11:26:22 AM »
Moto Guzzi was building 3 wheeled "goods vehicles" as early 1928, in various displacements from 50 cc to 500 cc.
Offline Dogwalker
« Reply #9 on: December 10, 2015, 11:42:02 AM »
The engine of the Mulo Meccanico was very different to those of the motorcycles. It had a dry sump, two camshaft at the sides of the block, pushrods on the external side of the cylinders, and parallel valves inclined 12 degrees in respect to the cylinder (wedge shaped combustion chambers).
That for the 500 was instead already very similar, with a wet sump, single camshaft in the same position of that of the v7, inclined valves and hemi heads.
« Last Edit: December 10, 2015, 11:44:18 AM by Dogwalker »
« Reply #10 on: December 10, 2015, 05:22:34 PM »
When I first went to Cina about 15 years ago you could see lots of these on the road spewing out black smoke from the single cylinder engine
Last time I went I only saw 1
« Reply #11 on: December 10, 2015, 05:51:17 PM »
These little Piago three wheelers where everywhere in Italy when I was in the north two years ago.
« Reply #12 on: December 11, 2015, 11:03:53 PM »
That sucker looks pretty darn new.  :cool: Wonder what size motor it has. When gas costs $15/gal., the streets are narrow, and you want to stay in business.......... :thumb:
Offline azguzzirep
  • Gratzi Carlo!
« Reply #13 on: December 12, 2015, 03:34:17 AM »
I see these kinds of things everyday. Ho hum.
Murphy's  Law sucks!
« Reply #14 on: December 12, 2015, 02:11:33 PM »
Probably the smaller scooter size engines....125 or 175 cc's engine.  https://en.wikipedia.org/wiki/Auto_rickshaw
