I agree on air cooling is simple and robust, but I don't quite get all the bashing of liquid cooling you see around here... Is liquid cooling really that bad? On an air cooled engine the temperatures across the engine varies wildly and tolerances have to be made accordingly. Also the engine temperature is very much dependent on the ambient air temperature. If you're stuck in traffic there's a big risk of engine overheating as there is no flow of cooling air, how good is that? As I see it liquid cooling has many advantages: Precise control of engine temperature in all situations. More even heat distribution across the engine no matter how the engine is positioned in the air stream. BMW's K75 and K100 bricks are perfect examples of this. Smaller risk of heat pockets which enables you to run a higher compression without the risk of pinging. It is possible to design a much more compact engine putting out the same amount of power as it is easier to get the heat away from the engine. Ugly radiators? That is something you can design your way out of, remember John Brittens V1000. Try to spot the radiator on that one! I have had my FZR600 for almost four years and used it as my daily transport when I was studying and I have never had a problem with the cooling system on it. Is the faliure rate and maintenance of liquid cooling systems really that bad? I haven't had any problems with my bike and no maintenance has been necessary. (I probably should change the coolant, but that will take me maybe half and hour every two/three years.) I understand the beauty and simplicity of the air cooled bikes and Moto Guzzi's have the ideal engine design to take advantage of air cooling, but is liquid cooling really a deal breaker? If Moto Guzzi made a liquid/air cooled engine similar to BMW's newer boxers/ Triumphs new twins/ Harleys liquid cooled heads would the liquid cooling be a deal breaker for you?
Bet the answers you get would be different if the question was:If you had a choice between two Moto Guzzi bikes, one air cooled and the other liquid cooled but made to appear identical aside from a well design and barely noticeable radiator, which would you choose?Thinking the wrenchers would go air cooled and everyone else liquid cooled.
And they all drive liquid cooled cars.
Cars are one thing, motorcycles another thing entirely. Given the choice and means ($$), I'd drive an air-cooled car too.
Yeah but the reasons so often given for the air cooled engine vs the liquid cooled on motorcycles are reliability. Reliability is reliability regardless of whether it is a car or motorcycle, it either runs or it doesn't.The facts do not bear out that liquid cooled motorcycles are inherently less reliable than those using air cooled engines. Liquid cooled bike engines often require less frequent maintenance than air cooled bikes and run with more consistent performance than air cooled bikes.Modern liquid cooled engines don't need fussing with from the cooling system standpoint, unless one is the type to walk around with screw drivers just to give er another twist to be sure. They work, are reliable and do an better job of cooling the engine than does air.It comes down to preference but the differences aren't in factor in reliability or ease of maintenance beyond anecdotal stories.
Had an air cooled VW bug back in the day. Damn engine was bullet proof but in winter you would freeze your arse off. Air on a bike, large hot water cabin heater in my cages please.
The Beatles I rode in had tons of heat in the winter, and when starting them cold, the heat was there quickly. They were probably 1970-ish.
Those had gas fired heaters, didn't they? VW is still doing something similar- the diesels have an electric aux heater since the coolant can take so long to warm up.
Never needed to rebuild the "air pump" for my air-cooled motorcycles, but have had to rebuild water pumps on a few liquid cooled ones. Never needed to replace the coolant hoses or change the coolant either on my air-cooled motorcycles. Then there are thermostats, cooling fans, fan switches and all of that other stuff. <shrug>
Only time I had issues with a Guzzi cooling not working was being overheated in traffic near Central Park and the Waldorf Astoria Hotel IIRC. LM V in NYC traffic with friend's wife on back. I started splitting lanes after the stall and she kept her eyes shut.
The simplest solutions are often the most robust . Like air cooling , gravity flow fueling ( carbs ) , plain brakes ( no ABS ) , paper maps , points ignition , wood stove in the house ...
Regarding air cooled cars the Beetle was only 40bhp from 1600cc
