Author Topic: Need help identifying a Moto Guzzi project '76  (Read 9546 times)
Offline GuzziDansker
« on: December 16, 2015, 01:30:04 PM »
Hi guys.
I've gotten my hands on a Guzzi project that I want to build a caf� from.
After having read around on the web, i'm confused as to what model it actually is. According to the paperwork it's supposed to be a Le Mans from '76.
But the frame number and engine number are matching, which i'm being told that shouldn't be the case on a old Guzzi.
The bike came from the US to Europe about 10 years ago but I don't know if it originally was from the US.
Anybody that can help shine some light on this? I know the front end is from a Suzuki.
Re: Need help identifying a Moto Guzzi project '76
« Reply #1 on: December 16, 2015, 01:51:06 PM »
I believe in the US the frame & motor ID #s should match. VE is LeMans I, II designation.  :wink:
« Last Edit: December 16, 2015, 05:17:57 PM by Arizona Wayne »
« Reply #2 on: December 16, 2015, 01:55:20 PM »
I believe in the US the frame & motor ID #s should match.  :wink:
:1:, My 72 Eldorado match
Is that a Tonti frame?
« Reply #3 on: December 16, 2015, 01:58:57 PM »
the fork wheel and brakes don't look like they are from Guzzi. I think the VE prefix on the VIN is a Lemans.
« Reply #4 on: December 16, 2015, 01:59:41 PM »
Yes, it's a Tonti frame & PHF carbs, black LeMans pipes.   Someone  painted the heads/cylinders/motor, etc. black too.
« Reply #5 on: December 16, 2015, 02:00:45 PM »
 He stated Suzuki .
« Reply #6 on: December 16, 2015, 02:23:04 PM »
Thx Dusty, got my glasses on now. Yep they look like Suzuki.
Offline guzzista
« Reply #7 on: December 16, 2015, 02:31:32 PM »
If it is a real 1976 Lemon perhaps it could be brought back to its former glory . Between the crashers and the  overly modded ones there are not  many left around...
« Reply #8 on: December 16, 2015, 04:07:42 PM »
Seems like the "VF" makes the frame an 850 Le Mans III affair but that leaves the engine out in the cold.
Too, isn't the final drive newer than the motor?
Todd.
« Reply #9 on: December 16, 2015, 04:14:28 PM »
Todd.
 Frame and motor numbers match .
« Reply #10 on: December 16, 2015, 04:28:38 PM »
I guess then, "This Old Tractor" gets it wrong from time to time.
Todd.
Offline Hahnda
    • Scrambler Cycle
« Reply #11 on: December 16, 2015, 04:31:28 PM »
Is it VF or VE? VF is the Lemans 3 and was a square fin.
« Last Edit: December 16, 2015, 04:31:51 PM by Hahnda »
1949 GTV - 1948 Airone
www.scramblercycle. com
« Reply #12 on: December 16, 2015, 04:38:06 PM »
Todd.
 OK let's reason this out . A PO searched around and found a motor that had numbers that matched the frame . I think conventional wisdom says the numbers don't have to match , not that they never
do .
« Reply #13 on: December 16, 2015, 05:21:12 PM »
VE designates LM 1 or 2 motor.
Offline Hahnda
    • Scrambler Cycle
« Reply #14 on: December 16, 2015, 05:43:47 PM »
I know. That's where my question comes from. It looks like a VF on the frame in the picture so that would make it a Lemans 3 and the matching number motor is a round fin. That's my confusion. If its actually a VE then it all makes a bit more sense.
« Reply #15 on: December 16, 2015, 05:48:14 PM »
I'm sure the LM1 & LM3 have the same frame as my CX100(LM2).  LM 4 frame is different.
« Reply #16 on: December 16, 2015, 05:50:53 PM »
Looking at it really, really hard, now, I can believe that it's a VE rather than VF. Makes more sense.
Todd.
« Reply #17 on: December 16, 2015, 05:59:42 PM »
Are the carb manifolds attached with 6mm or 8mm bolts?  6mm = 850 LeMans.  8mm = Other
« Last Edit: December 16, 2015, 07:47:10 PM by Cam3512 »
Offline jacksonracingcomau
« Reply #18 on: December 16, 2015, 06:50:29 PM »
No, LM3 is frame breather, your CX isn't, neither is OP's, LM4 slightly different again
VE correct
Offline motogman
« Reply #19 on: December 16, 2015, 07:30:54 PM »
VE correct
What is a "frame breather"?
« Reply #20 on: December 16, 2015, 07:37:46 PM »
 Engine breather blows into the frame .
« Reply #21 on: December 16, 2015, 10:44:12 PM »
Frame and engine block numbers should match if original.  However the frame number would be used as the VIN for title purposes.  If the engine was changed out the frame number would still be used in the title.  In other words, it's possible to have a titled '76 titled frame bike with a different year engine in it.  Caveat emptor if you're looking for an original LM1.
« Reply #22 on: December 16, 2015, 11:36:46 PM »
Wow I had no idea I could get this much help in that short time :)
I will go later today and take a closer look of the frame+engine number, and get better pictures of everything.
Thanks guys!
Online John A
« Reply #23 on: December 17, 2015, 11:08:37 AM »
The carbs look like PHF's. What size are they ?
« Reply #24 on: December 17, 2015, 12:46:44 PM »
Thanks guys!
Hard to beat WG..  :thumb: I've never gone more than 12 hours without an answer, no matter how strange a question I ask.  :smiley:
It's the main reason I make a small donation every year. (hint, hint)   :wink:
« Reply #25 on: December 17, 2015, 12:58:26 PM »
Doesn't necessarily mean you'll get a relevant and/or correct answer.  :-0
« Reply #26 on: December 19, 2015, 12:29:32 AM »
Okay so I took a closer look. It does in fact look like the frame number says VF and not VE, but the stamping is pretty shitty so I guess it could be both.
The carbs are 40mm and the intake bolts are 6mm.
Offline nc43bsa
« Reply #27 on: December 19, 2015, 12:51:47 AM »
That looks like a Commando in the L foreground.
That's all I got.   :grin:
1990 MilleGT
« Reply #28 on: December 19, 2015, 12:59:25 AM »
The Guzzi is in one of our storage rooms where i work. We have more than a 100 old bikes in different conditions, so it's easy to find a project :)
We know nothing about old Guzzi's though, so thats one of the reasons why I want to build this one. And it's a cool bike  :bow:
Offline Anders Pedersen
« Reply #29 on: December 19, 2015, 09:04:47 AM »
Hello GuzziDane!
Now where in Denmark would that be, if you don't mind me asking?
Med venlig hilsen Anders
'92 1000 Le Mans V u.e.
'92 BMW R 650 G/S
