Author Topic: V65 Gearbox replacement - help with ID number  (Read 3518 times)
Offline chrisk
« on: December 24, 2015, 09:14:54 AM »
Hi, I'm looking at a replacement gearbox for my 1981/2 v65, the one I'm looking at is stamped D-002829
The guy says its from a v65, but it has marker pen  on it saying v50iii, v65/v75.  How do I know what it's actually from? I know that a v50iii and v65 have different ratios, not sure about a v75. Either way how can I tell what's it's from?
The was a post from MWRenn saying the following which probably means it's from a late v65???
" in 1983 MG updated the V65 and V65SP transmission gears and mainshaft with new parts, starting with number 2253. These are not interchangeable with transmissions before the update. Basically, the mainshaft is different, as well as 5th  4th, 2nd, and 1st gears on the mainshaft and layshaft"
Offline wymple
Re: V65 Gearbox replacement - help with ID number
« Reply #1 on: December 24, 2015, 10:05:45 AM »
My son replaced the trans in his 84 V65 with one from a V50. There was a minor difference that I can't remember exactly. I will see him later today and get up to speed on what he did. It works fine.
Offline chrisk
« Reply #2 on: December 24, 2015, 12:10:01 PM »
Ratios are definitely different between v50 and 65,  I checked I the manual...
« Reply #3 on: December 24, 2015, 01:28:07 PM »
"Early" input shaft has approx. 17 mm splines, "later" has 22 mm. Some V50 III and Monzas may have the 22 mm, but mostly it's found on V65 and V75/V7 'boxes.
Offline SED
« Reply #4 on: December 24, 2015, 05:02:28 PM »
Charlie does that mean you can adapt a 22mm spline 'box to a 17mm spline bike by swapping the clutch disc?
Thanks & Merry Christmas
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
« Reply #5 on: December 24, 2015, 05:11:34 PM »
I think that's all it would take. Not a small-block expert though.  :wink:
Offline SED
« Reply #6 on: December 24, 2015, 05:16:36 PM »
Thanks Charlie!
Also noticed this...
This is true of the reduction ratio between the clutch and gearbox, but is it true of the gears themselves?
BTW pretty sure reduction ratio is the same for V65 and V50 Monza.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #7 on: December 24, 2015, 05:36:03 PM »
Me, either, but I agree.
I put a Breva transmission in the Lario, and it was an easy swap. There are some differences, but nothing that will keep you from doing it. It has a *much* improved breather setup to boot.
Offline SED
« Reply #8 on: December 24, 2015, 05:41:05 PM »
I remember that now!  Good to know.   :thumb:
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Hymes Inc.
« Reply #9 on: December 24, 2015, 06:17:10 PM »
Dad is mistaken here. I bought a case section from a V50 because it looked similar but had a few small differences that made it not work. Ended up buying a complete transmission off ebay from a 1984 V65.
