Author Topic: Install a relay? Yes or no?  (Read 2505 times)
Offline bigbikerrick
« on: January 13, 2016, 02:40:23 PM »
Hi Folks I am adding 2 led daytime running lights to my LeMans. they draw 10watts each. I am running a wire from the fuse box to the lights for 12v+ and am running a separate ground wire which I plan to interrupt with a toggle switch to turn the lights off. My question is since I have only a 20 watt draw should I install a relay, or is it un necessary due to the small amount of current these lights draw? I already have relays in place for the horns, hi low beam , and the starter.
Rick
Offline Tobit
Re: Install a relay? Yes or no?
« Reply #1 on: January 13, 2016, 03:08:32 PM »
You could run them off the relay you've installed for the lo beam and interrupt their ground with the toggle switch.  That way, whenever the low is on you have the option of turning on the driving lights.
Roman, '86 LM IV
« Reply #2 on: January 13, 2016, 03:19:13 PM »
No, you don't need a relay for a couple of Amps
Horns really benefit from relays and a large feed wire direct from battery, the regular wires are usually too small, equate it to the welding cable they put on car speakers.
« Reply #3 on: January 13, 2016, 05:01:26 PM »
No relay required.
Not only that, but LEDs have regulators in them, so it can't be any brighter, even if it does get a few extra tenths of a volt.
« Reply #4 on: January 13, 2016, 06:02:36 PM »
No relay required.
Excellent Point
« Reply #5 on: January 13, 2016, 06:20:08 PM »
 Thank you folks, I appreciate the responses. I will shoot a couple pics of the lights and the  bracket I fabricated to mount them, and post them here later.
Rick.
Offline ITSec
« Reply #6 on: January 13, 2016, 06:30:10 PM »
I'm going to be contrary - I believe (especially on motorcycles) that using relays to isolate accessories is almost always a good idea, as long as you buy quality relays. The circuit you describe probably doesn't need one from a draw/demand perspective, but it's always nice to have one so that you can isolate issues and improve reliability.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #7 on: January 13, 2016, 09:46:02 PM »
Another bit of hardware to go wrong; how does this increase reliability?
A simple fuse will provide all the isolation you need.
« Reply #8 on: January 13, 2016, 10:47:30 PM »
Just another point of failure. Another good reason to NOT add a relay.
