If you are single, or your significant other doesn't mind, and if this is a complete disassembly........ put it in the oven at 350-400 degrees for an hour or two. (please wrap up the transmission good in heavy duty aluminum oil, or your next steak will taste like an Applebees steak. They should come right out. I've tried localized heat (Mapp Gas torch) with no luck
250.....that's a BSA
into the oven it goeswhat's a good temp to heat it too?
Out here we got the Triumph 250 Trophy and the BSA Starfire 250. Wot came first, the chicken or the egg?
