Author Topic: every holes a goal  (Read 3919 times)
omega1987
every holes a goal
« on: January 17, 2016, 03:59:50 PM »
http://postimg.org/image/o5gq4qqs/
Hello all, just a quick question regarding the smallblock transmission oil change.
I believe the oil should be drained from (C) and topped up via (A) but what's (B) for and why shouldn't you refill via it?
Sorry if this is a daft question.
« Last Edit: January 17, 2016, 04:00:24 PM by omega1987 »
Re: every holes a goal
« Reply #1 on: January 17, 2016, 04:57:52 PM »
If you mean the rear drive. A is the oil level hole, fill until the oil just starts to run out. B is the oil fill and C is the drain.
Hope this helps,
omega1987
« Reply #2 on: January 17, 2016, 05:10:10 PM »
Hope this helps,
Thanks Tom,
Yes I was referring to the rear drive. I was just curious because the how-to guide I've seen show people filling the rear drive via (A), not (B).
« Reply #3 on: January 17, 2016, 05:12:38 PM »
A is the fill hole, B is a breather.
« Reply #4 on: January 17, 2016, 05:17:07 PM »
Sorry, didn't know the small blocks had a breather where the fill is on a big block. I learn something new everyday!
omega1987
« Reply #5 on: January 17, 2016, 05:36:09 PM »
Ok thanks for clearing that up.
Just out of curiosity, could the rear drive be filled via the breather (I.e. If you undid the bolt) or would the oil end up somewhere it shouldn't. Obviously it would be best practice to fill it via (A) to prevent overfilling.
« Reply #6 on: January 17, 2016, 05:38:42 PM »
Yea, PITA filling through what was normally the level plugs on big blocks.  The fill holes on both the tranny and rear are on the sides!
« Reply #7 on: January 17, 2016, 05:40:41 PM »
Yes, but it's a much smaller hole.  I always measure the proper amount, then pour it in.
omega1987
« Reply #8 on: January 17, 2016, 05:48:44 PM »
Thanks Cam  :thumb:
Offline BMCMOTO
« Reply #9 on: January 17, 2016, 06:43:31 PM »
I never use that A hole to fill the drive, I always use the B hole.  I also always measure the amount, same for the other gearbox.  I lean the bike way over and lean it on a milk crate to fill the gearbox.  Small blocks are very sensitive to gearbox level, 1 full liter is a must.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline SED
« Reply #10 on: January 17, 2016, 11:19:00 PM »
Omega,
The level hole only works if the swingarm is horizontal.
Put it on the center stand, remove the two top shock bolts and put blocks under the rear tire until the swingarm is level and hole A should be at the right height for the oil level.  At least this works on a V50 Monza.
There is a baffle below the hole at B that makes it very slow to pour oil in even after pulling the breather.  Hole at A is larger with no baffles.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline v65tt
    • Streffords
« Reply #11 on: January 18, 2016, 06:22:51 AM »
I always fill mine via the breather hole. I use a large syringe to do mine.
As said above the level plug is only of use if the swingarm is horizontal .
If found on my tt I get about 100ml in before the level plug is starting to weep.. that makes it 70ml short
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
Offline M0T0Geezer
    • The Ones I Rode
« Reply #12 on: January 18, 2016, 07:44:34 AM »
I second that.
'Geezer  ('04 Breva 750  42,000 miles)
Much small block info: http://www.dansher.com/bikepix/Guzzi/_V7_fyi.txt
Wisdom from the road:
