Author Topic: Any difference in state of tune of B11 and G11?  (Read 6946 times)
« on: January 23, 2016, 07:23:24 AM »
Did the Griso 2v 1100 and Breva 1100 use an identical engine (same state of tune,) or did Moto Guzzi configure the Griso to have higher performance?
« Last Edit: January 23, 2016, 07:39:19 AM by ohiorider »
Re: Any difference in state of tune of B11 and G11?
« Reply #1 on: January 23, 2016, 08:55:04 AM »
I can't say if there were different camshafts off the top of my head (though a check of Harper's OEM parts list might answer that), but exhaust system and muffler differences and probably different mapping, and possibly different gearing (I believe the B11, B12, and Norge had different final drive ratios) all seem to show in different rwhp ratings.
« Reply #2 on: January 23, 2016, 09:06:30 AM »
Thanks for the Harper's suggestion.  At this time its simply a curiosity thing.
Offline guzziownr
« Reply #3 on: January 23, 2016, 09:33:46 AM »
Reviews commented on the Griso's lower gearing.  No mention of a higher state of tune.
Moto
« Reply #4 on: January 23, 2016, 09:38:50 AM »
Same camshaft and throttle body; different air box, filter, and exhaust. Griso had 4.5 more rwhp, per MCN.
Lower gearing per se doesn't affect rwhp; it's a measure of work per unit of time.
Offline flip
« Reply #5 on: January 23, 2016, 09:39:31 AM »
Didn't the Breva 1100 have the tallest gearing of the CARC bikes?
North Carolina
« Reply #6 on: January 23, 2016, 10:22:26 AM »
It's been a while, but I think the Norge or B12 Sport was even taller geared.
« Reply #7 on: January 23, 2016, 10:51:33 AM »
Yep  -  confirmed the cams are the same ..... same PN on Harpers for the G11 and B11 camshafts.
Offline guzziownr
« Reply #8 on: January 23, 2016, 10:54:49 AM »
Measured at the brochure?
Professor, is this going to be on the final?
Moto
« Reply #9 on: January 23, 2016, 12:08:29 PM »
Measured by Motorcycle Consumer News, on the same dyno, four months apart.
You bet your bippy it will be on the final.
Moto
Moto
« Reply #10 on: January 23, 2016, 12:14:47 PM »
And the ECUs have different part numbers. I think they are the same model with different software, but I don't know.
So, intake, exhaust, and ECU must account for the 4.5 hp.
Moto
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #11 on: January 23, 2016, 02:07:25 PM »
No, the Breva 1100 was the taller geared version.  The Norge, Griso, and 1200 Sport are all lower geared.  (for the 2V).
« Reply #12 on: January 23, 2016, 02:29:53 PM »
I could have sworn that JohnVT or someone else insisted one of them was taller... But I'll take your word for it, <shrugs>
Offline guzziownr
« Reply #13 on: January 23, 2016, 02:40:58 PM »
Moto
Verry interesting!
« Reply #14 on: January 23, 2016, 03:15:37 PM »
Roy is correct. The B11 is the tallest geared. The 4.5 HP difference is almost certainly down to how badly one was tuned compared to the other. While the pipes and induction system will make a difference it is unlikely to make that much of a difference on otherwise identical engines.
As for the ECU's. Yes, different mapping, but all the W5AM units used on Guzzis are interchangeable, they just require having the correct map loaded. Things like the speedo correction factors for ABS bikes are different which makes it fun as you can go really, really fast just going out of the driveway! :D
Moto
« Reply #15 on: January 23, 2016, 09:36:25 PM »
Yes, no doubt you're right. I just found reviews of both by Rider magazine, in which the Breva came out 1.2 hp ahead.
« Last Edit: January 23, 2016, 09:38:05 PM by Moto »
« Reply #16 on: January 23, 2016, 10:55:11 PM »
If you look up the Vintage internals, it's also the same motor parts, same homogenized crap
« Reply #17 on: January 24, 2016, 05:26:38 AM »
That strikes me as a strange attitude, mind if I ask why you say that?
« Reply #18 on: January 24, 2016, 07:32:25 AM »
There was a time w/hot rods had different cam, heads, etc, not just some different fueling.
« Reply #19 on: January 24, 2016, 07:50:02 AM »
You can still find that, but not from a small company with minimal sales who only charges another grand or two for one model over the other.
« Last Edit: January 24, 2016, 08:42:39 AM by Kev m »
« Reply #20 on: January 24, 2016, 08:34:41 AM »
You can still find that, but not from a small company with minutes sales who only charges another grand or two for one model over the other.
There's a company that just may be doing that.  Though I haven't yet seen a good set of specs on the new Bonnies and Thruxtons, Triumph alludes to the 1200cc Bonneville T120 as having a "high torque" engine vs the Thruxton's "high power" engine.  When we attended the showing of the new bikes in early December 2015, the factory reps also made a point of the difference.  Unfortunately, unless it's been published within the past few days, I've seen no comparative dyno charts or a side by side comparison chart.
« Reply #21 on: January 24, 2016, 08:44:21 AM »
Yup, and Triumph WW annual sales figures are what in the 55k range or as much as 11x MG's annual sales.
« Reply #22 on: January 24, 2016, 08:47:02 AM »
They (Triumph) just had a schooling on the new motors here this past week, at their newest dealer here in GA. Massive amount of room at that place. GA needed a good Tri dealer in their home based state.
