Author Topic: Now for something completely different....BMWK75s  (Read 17700 times)
Offline leafman60
Re: Now for something completely different....BMWK75s
« Reply #30 on: January 30, 2016, 08:28:13 PM »
Lots of good points made.
One thing, maybe already mentioned, is that many of the early year K bikes had a propensity to issue a sizable cloud of blue smoke upon starting. This was due to the cylinder heads being positioned on the left side of the bike.  When the bike was stopped for a while, especially when leaned over on the sidestand, oil liked to migrate down the cylinder walls, past the piston rings and into the head.  This was helped by the vacuum caused by the cooling of the heated combustion chamber.
The engineers tried to improvise a fix with bleed valves made into the pistons to break the cool-down vacuum that liked to suck oil downstairs into the combustion chamber.
Amazing that big-shot engineers could not anticipate such a problem and did not notice it during pre-production trials.
Offline Carlo DeSantis
« Reply #31 on: January 30, 2016, 09:29:48 PM »
I had a '91 K75 that never smoked on startup and I usually parked on the sidestand.  My understanding was that after the first year or so of production, BMW began to pin the rings; apparently if the rings were aligned (or nearly so) the oil could seep past them.
As for my K75, I loved it.  It fell victim to a BDC a few years back.  I thought long and hard about replacing it with another one, but decided to go for a lighter bike with more modern tech.
Not many riders have been disappointed with K75 ownership.
Best,
Carlo
Chuck in Illinois
Crystal Lake, IL USA
'75 850 T3 Custom
'11 R1200R
George_S
« Reply #32 on: January 31, 2016, 03:13:26 AM »
We just had the annual dinner of our small BMW club last night. One of our longtime members has 500,000 miles (that's not a typo) on his current K75, I can't recall the model year, and the engine has never been totally rebuilt. He was listed in the BMW owners news an issue or two back as a million miler. Some miles was put on a Suzuki years ago and he needs 40,000 more miles I think on his BMW to have a million on just BMWs. Not too shabby for a North Jersey based rider where we have winters with snow.
Offline leafman60
« Last Edit: January 31, 2016, 06:54:47 AM by leafman60 »
« Reply #34 on: January 31, 2016, 08:20:07 AM »
Here's a rundown of the mechanical changes to the K75/K100/K1100 series from a respected BMW source:
http://largiader.com/k75/khistory.html
Best,
Carlo
PS: For my money, the '94 and '95 models are the best pf breed, so to speak.
Chuck in Illinois
'75 850 T3 Custom
'11 R1200R
Offline sturgeon
« Reply #35 on: January 31, 2016, 09:17:08 AM »
If you're interested, there's a thread over on advrider about interesting things people have done with K75's
http://advrider.com/index.php?threads/specialks-net-bmw-k75-custom.657248/
Dyslexics Untie!
11 Yamaha WR250R
14 Moto Guzzi V7S
16 BMW R1200R
Offline leafman60
« Reply #36 on: January 31, 2016, 09:27:45 AM »
I remember the K75 well.  I was attracted to the sleek, red K75S.
I took one for a test ride, however, and my attraction waned afterwards.  I was accustomed to twins, was riding a Ducati 900SS at the time.  The K75 seemed like a sewing machine to me. Too smooth. Too sanitized. Also, the low-end punch was not as strong as my twins.  Seemed like I had to really get the K75 spinning up its motor pretty high before having notable punch.
Just my opinion.
Many of my friends liked them. I do remember the start-up smoking from some of them and the efforts of BMW to fix it even though it was nothing that caused serious problems.
« Last Edit: January 31, 2016, 09:28:26 AM by leafman60 »
Offline jbell
  • Some progress
« Reply #37 on: January 31, 2016, 09:44:51 PM »
Own a '92 K75RT since new.  62K miles.  Agree with most of the previous good reviews.  I've had a few problems with mine, ABS computer replaced under warranty and the main computer replaced at about 45K for $150 for a used one.  Never had to trailer it home.  Do my splines every 15K and at 60K, they all looked good. Oil filter (5K) is a little messy to get to but the fuel filter (15K) in tank is easy to replace.  Plugs (10K) are easy to get to and checking valve clearance (15K) is fairly straightforward.  I replace coolant and flush brake fluid every other year,  tranny and rear drive with Mobil 1 every 10K.   I'd like something newer with more power but this bike does everything I really need and just keeps running smoothly.  Average about 45 mpg.
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
Online sdcr
« Reply #38 on: February 09, 2016, 11:50:37 AM »
The clutch splines are critical. W/abs and a lift it took ~8 to 10 hours to pull and re-install. The splines are on the trans, mainshaft. Once the female splines on the disc begin to wear it all worsens over time and miles. I put 7 clutch discs in mine. About one every other tire change. bmw said there was nothing wrong and it was normal wear.
 R3~
So, just to be clear, are you saying it takes 8-10 labor hours to do the Spline lube? I've had this Done at my BMW dealer on my R1100 RS, and IIR , it was something like a 2.5 hour job. Is the K75 setup so different that it take up to 7.5 extra hours?
1983 Le Mans III
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #39 on: February 09, 2016, 03:18:03 PM »
I do not have experience with spline lubes on an ABS bike, but I have done it several times on non-ABS K75s and K100s.  The first time around there will be extra time needed because -- well -- it's the first time.  After that, the job is 2 or 3 hours at most.  That's in my garage with a bike lift table.
Be sure to get a replacement mica exhaust gasket from the dealer to replace the one that will fall apart when you pull the muffler.  It also helps to have some clutch locater pins if you're doing the job by yourself.
Best,
Carlo
Chuck in Illinois
'75 850 T3 Custom
'11 R1200R
Offline cookiemech
« Reply #40 on: February 09, 2016, 03:47:48 PM »
Cheaper to just buy three copper gaskets for header/cylinder head junction and remove the entire system when doing a spline lube.
Offline segesta
« Reply #41 on: February 09, 2016, 04:09:47 PM »
LBC Tenni: great looking bike, nice job.
2013 Ducati Monster 796
2010 BMW K1300GT
« Reply #42 on: February 09, 2016, 05:05:49 PM »
Never compared the cost, but a couple of things to remember: (1) probably good to replace the mica gasket as PM anyway and (2) it's waaaay easier to pull the can vs the whole system -- especially since the the mount studs/nuts at the heads are often rusted tight!
Chuck in Illinois
'75 850 T3 Custom
'11 R1200R
