Is it mounted backwards?
I have a Bridgestone Battle-Wing 502 Rear 140/80R-17 V rated tire that has less that 100 miles on it left over from a failed project. If anyone can use it, the price will be right. Not sure what you would use for the front but if anyone in the Phoenix area can use it send me a PM the price will be right. I don't have anything it will fit now and it should be used while it is still fresh.
Yes, it is.
If you must have a knobby knobby, another good tire is the Metzeler Sahara. They have a 120-18.
:coffee:dI knew it was, guess I should've more properly asked, why? Seems kinda useless the way it is with the tread backwards. Looks like maybe it's a rear and someone mounted it according to the direction arrow on the sidewall.
Again it is not mounted backwards and it is a front tire. I mounted it myself.
Wonder how this trials tire would handle on the front. It is the only thing I have found so far that is actually tubeless. http://www.motorcycle-superstore.com/15011/i/irc-tr-11-trial-winner-trials-rear-tire
