Seems most "experts" don't think it necessary to warm an engine up anymore . Of course the next post will dispute this ... Dusty Edit , actually the first post LOL .
Source? Citation?
Uh , those two no-nothings Click and Clack on car talk . Oh , wait , weren't they both MIT trained automotive engineers Listened to them for years on NPR , trust them juuusssst a bit more than some internet expert . Dusty
Cold is fine. Hot is fine,too. Changing it is the important thing. Terry
HOT OIL IS MORE FLUID AND WILL DRAIN OUT MORE EASILY AND COMPLETELY; IDEAL TEMPERATURE IS REACHED AFTER THE ENGINE HAS RUN FOR ABOUT TWENTY MINUTES.
Words of wisdom from a professional engine rebuilder . Modern high detergent oil keeps the little stuff suspended hot or cold , and anything big enough to do immediate damage is caught by the filter . If an engine is really full of sludge , a simple oil change will not remove it . That requires at a minimum a sump removal and a good cleaning . Dusty
For the Jackal, I always drain the oil cold, but I drop the pan to clean it out anyway.
Let me throw a log onto this fire;Opinions on changing the oil prior to winter storage?
OK, I'll bite. I've seen an explanation that leaving dirty oil in all winter isn't good because of the acids? And if you're in the North, each freeze/thaw cycle during the winter makes about a teaspoon of water form in the oil pan. Does it burn off quickly on your first spring ride? I dunno, nor make any opinion as to the two things mentioned, they're not my comments so don't shoot me.
