Author Topic: Timing gear conversion for 750 small-block?  (Read 1835 times)
omega1987
« on: January 31, 2016, 03:08:33 PM »
Hello all,
I've been reading some interesting stuff about big-block timing gear conversions but I've been unable to find any topics discussing the same conversion for small-blocks.
Is that because the small-block simply can't accommodate timing gears or is there some other reason why this isn't a done mod?
P.S. I'm not currently looking at doing this mod, just curious  :smiley:
« Last Edit: January 31, 2016, 03:11:00 PM by omega1987 »
Re: Timing gear conversion for 750 small-block?
« Reply #1 on: January 31, 2016, 03:25:32 PM »
I personally haven't seen a need for it on a street v750.
« Reply #2 on: January 31, 2016, 03:43:40 PM »
As far as I know, it hasn't been done. The timing chain and tensioner on the small block is really robust. (Ahem) A better system than on the big blocks, IMHO. On the older ones, timing is taken directly off the end of the cam, to boot. I wouldn't think there would be much of anything to gain by doing it.
omega1987
« Reply #3 on: January 31, 2016, 04:17:02 PM »
Ok that's interesting, so the big-block timing chain only exists because the timing chain/tensioner is of a weaker design.
I must admit that there's a certain appeal for having a chainless motorcycle even if the timing chain is long lived and a shaft driven Guzzi would be an obvious choice.
