Author Topic: Looking for Le Mans handlebar switch  (Read 2707 times)
Offline bigbikerrick
« on: February 04, 2016, 01:56:31 PM »
Hello Folks, in case someone has one laying around collecting dust, I am in need of a right hand (Throttle side) switch assembly for my 85 Lemans IV. This is the rather strange switch assembly that has the high/low beam toggle on the throttle side....I sometimes wonder what  the heck Guzzi was thinking with that arrangement, not to mention the" up down" turn signal switch setup on the other side!  :angry:
Thanks in advance,
Rick.
Offline Curtis Harper
    • Harpers Moto Guzzi
Re: Looking for Le Mans handlebar switch
« Reply #1 on: February 04, 2016, 02:17:05 PM »
Also used on the Lario and T5
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline double.d
« Reply #2 on: February 04, 2016, 02:44:32 PM »
I can understand you wanting to keep the switchgear original, as i did in the early days, but there will come a time when you are sick of them letting you down at inopportune times and trying to fix contacts that have melted themselves into the plastic housing............ .....just saying.
1986 Le Mans IV Black Since New
2014 K1300 R Black German Starship.
« Reply #3 on: February 04, 2016, 03:40:06 PM »
Double D, I am not all that anal about keeping the switchgear original, like on my Cal II i got rid of all the" lego" switches, and went with a tommasselli daytona throttle etc., but on this lemans, the switch housings are part of the master cylinder /throttle, and the clutch lever mount on the left side. I would have to change all the levers, throttle, front brake MC. Its quite an undertaking, and I already have a new switch assembly on the clutch side.
Rick.
« Reply #4 on: February 04, 2016, 03:42:34 PM »
Thank you, Curtis. I didnt know that. Do you guys have any? New or used.
Rick.
Offline LeRoy
« Reply #5 on: February 04, 2016, 03:49:57 PM »
As you point out, Guzzi did us no favors by combining that questionable and unique switch with the also unique trapezoidal master cylinder. As a result, you have to change everything to change anything.
That being said, I have a spare of the switch in question. It looks very good from the outside. On the inside one terminal shows evidence of overheating. I'll test continuity and function and see how it works electrically. As you can imagine, this switch will have a much easier and longer life when you convert the headlight to relays for high and low beams. In the meantime, if you're interested send me a PM and I'll send you a couple pictures and we see if it would suit your needs.
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
« Reply #6 on: February 04, 2016, 04:05:33 PM »
I don't have anything. BUT I may have the part of the switch that is bad. But LeRoys fix may be more affordable.
www.harpermoto.com
1-816-697-3411
« Reply #7 on: February 11, 2016, 12:06:00 AM »
Leroy, I sent you a PM.
Thanks,
Rick.
« Reply #8 on: February 11, 2016, 05:40:54 AM »
I overhauled the switch gear on the Lario, and did a tutorial in the Lario rehab thread. Once you get it working, put relays on everything, including the kill switch. They are very small wires and not the most robust pieces of copper in the world. They've worked fine since.
« Reply #9 on: February 11, 2016, 01:08:06 PM »
I think I have one, just got a LMiv front end a few months ago, I will check tonight
