Author Topic: Sealing front forks  (Read 4887 times)
Offline ritratto
Sealing front forks
« on: February 11, 2016, 05:27:45 PM »
Hey all,
Rebuilt my forks  ('78 G5 with adjustable dampers and Wirth progressive springs and new top seals) about 3 weeks ago and both have started to leak from the bottom bolt. (one was pretty soon, the other just last night) Have new crush washers coming and want to know if there is a trick to making them seal well.
Thanks,
Ted
1978 G5
1998 Centauro ( oppsidaisy!)
2003 V11 LeMans
Re: Sealing front forks
« Reply #1 on: February 11, 2016, 05:54:56 PM »
 I've had some luck with O rings and teflon tape .
Offline ritratto
« Reply #2 on: February 11, 2016, 05:59:42 PM »
So Dusty,
Tape on the bolt and an o-ring the size of the bolt, under the crush washer?
1978 G5
2003 V11 LeMans
« Reply #3 on: February 11, 2016, 06:14:46 PM »
So Dusty,
 Yeah , although crushing the washer can be tricky . I have a collection of fiber washers to use with a new washer . My old /5 had a teen einstsy little nick on the mating surface that almost made me crazy until using a magnifying glass to see it . A quick cleanup with a piece of emory cloth fixed the problem . Amazing what hydraulic fluid can leak past  :laugh:
« Reply #4 on: February 11, 2016, 06:18:30 PM »
You can apply thread sealant to the bottom fork damper bolt and the drain bolt along with new crush washers.
« Reply #5 on: February 11, 2016, 06:45:27 PM »
Well, I have some dead soft 3003 1/16" aluminum, and just make new crush washers because I can.  :evil: :smiley:
Woo hoo! Emoticons worked..  :thumb:
« Reply #6 on: February 11, 2016, 06:55:34 PM »
I use a liberal application of Hondabond 4 to the underside of the bolt head and washer.
Might try some of these sealing washers on my project bike.
http://www.mcmaster.com/#93786A175
« Reply #7 on: February 11, 2016, 07:57:39 PM »
 The stock BMW washers resembled those , never could find a source . Thanks Charley .
Offline drlapo
« Reply #8 on: February 11, 2016, 08:04:18 PM »
My local AutoZone store has the sealing washers but I don't know if they have 6 or 8mm
Offline ritratto
« Reply #9 on: February 11, 2016, 08:15:30 PM »
What kind of washers are you speaking of drlapo?
1978 G5
2003 V11 LeMans
Offline tris
« Reply #10 on: February 12, 2016, 06:55:15 AM »
isn't that just a Dowty Washer AKA bonded seal?
http://www.ebay.co.uk/sch/i.html?_nkw=dowty+washers
1993 TW125 "POS" - Resting
Offline mtiberio
    • TiberioRacing
« Reply #11 on: February 12, 2016, 07:01:16 AM »
Happened to me recently. I simply took my air driver and rattled the heck out of the bolt. I assume it mushed the crush washer real good...
Cannot visualize how teflon on the threads would help...
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
redrider
« Reply #12 on: February 12, 2016, 07:13:12 AM »
Remember the Honda Hawk V twin? External oil lines with copper crush washers. Damn thing would start weeping after every service. New crush washers lasted a month or so. Drove Steve nuts and costly to replace for him. He was not happy. I used a butane pencil torch to re-anneal the old ones. Heat gently using a circular motion until the copper changes color to a rainbow bluish tint. Let cool naturally and install. Voila! No more leaks even with "used" items. I also did this to new ones and have never had a problem. Aluminium behaves similarly but I prefer copper.
Offline CT Dharma
« Reply #13 on: February 12, 2016, 08:24:41 AM »
Hey all,
Thanks,
Ted
A timely post as I'm also in the midst of rebuilding front forks [springs, seals FAC dampers] on my SP; keep us posted on how you make out.
1980 SP1000 original owner
1998 V10 Centauro
1982 Honda CX500TC Turbo
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
"When I'm riding my motorcycle, I'm glad to be alive. When I stop riding my motorcycle, I'm glad to be alive" - Neil Peart 1952-2020
« Reply #14 on: February 12, 2016, 11:18:16 AM »
 The original BMW washer was a bit different , I think .
Offline mtiberio
    • TiberioRacing
« Reply #15 on: February 12, 2016, 12:50:47 PM »
actually you quench copper or aluminum to soften. opposite of iron alloys.
Offline ritratto
« Reply #16 on: March 26, 2016, 12:18:31 PM »
A final update after a month of riding. Still sealed well. Stock washers from M.G. Cycle and some thread sealer.
I did do the initial torque and then let it sit overnight and re-torqued before reassembly.
1978 G5
2003 V11 LeMans
« Reply #17 on: March 26, 2016, 03:06:48 PM »
I use a liberal amount of RTV on mine.  Has worked for 30k miles
