Author Topic: 2013 v7 racer battery overcharging  (Read 3987 times)
dabrucru
« on: February 17, 2016, 12:36:48 AM »
Hi all i m new to guzzi , i ve had mine since last december, it has just covered 5000kms its a 2013 model. i have this little issue with the battery. its getting 15.1 charge. the mechanic told me that its a bit high. should i be concerned? do i need to change the voltage regulator? any advice is greatly appreciated. everything else works fine...never had an issue not even the previous owner.
thanks
david
Re: 2013 v7 racer battery overcharging
« Reply #1 on: February 17, 2016, 03:53:46 AM »
That is a bit too high, should be 13.7, Have it swapped out.
dabrucru
« Reply #2 on: February 17, 2016, 03:56:54 AM »
thanks
« Reply #3 on: February 17, 2016, 06:16:42 AM »
Steve, is high ever the grounding/ground strap? Should he check that first?
Offline pyoungbl
« Reply #4 on: February 17, 2016, 06:51:07 AM »
FWIW, I had the same problem with my '13 V7.  Replaced the Regulator/Rectifier and now it's OK.  15.1V is going to kill the battery.
Peter Y.
'13 V7 Special (red/white)
Offline sign216
« Reply #5 on: February 17, 2016, 06:52:41 AM »
Yeah, it's cheaper and easier to check the ground than to buy a new part.  If it's like the previous model, the regulator ground strap goes to bolt on the right side of the engine case, where it meets a wire from the battery.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #6 on: February 17, 2016, 06:59:20 AM »
Yeah, if the ground is bad, it'll overcharge. Do that first. It may not cure it, but if it does.. it's FREE. (Guzzi content)  :smiley:
Edit:
Welcome to WG. Since you're new, run a 14 gauge wire from the regulator case to an engine bolt. Put star washers under both ends.
« Last Edit: February 17, 2016, 07:01:40 AM by Chuck in Indiana »
Offline sign216
« Reply #7 on: February 17, 2016, 07:03:58 AM »
Edit:
Chuck, the latest regulators have a dedicated ground strap.  They no longer ground through the case.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #8 on: February 17, 2016, 07:43:46 AM »
Joe
If it's a strap, I stand corrected. The earlier ones had a dedicated wire, but it was too small.
redrider
« Reply #9 on: February 17, 2016, 10:32:36 AM »
Batteries are 14.04 VDC by design and the physics of lead/acid. New, at rest with no connections will be slightly less due to internal resistance and ambient temperature. Amperage or current if too high will cook the battery long before 15.1 VDC has any negative effect.
« Reply #10 on: February 17, 2016, 11:05:54 AM »
If it's an Odyssey, 15.1 will kill it. Says so right in the charging directions that come with the battery.
