Author Topic: 1100 Sport Carb MR1 forks- how to make better-er  (Read 4546 times)
Offline Greenman
« on: February 21, 2016, 12:46:53 PM »
I've fiddled with my marzocchi forks for years,  fitted the WP springs instead of the floppy standard ones, and dropped them through the yokes 15mm.
But how do you rebuild the cartridges? is it even possible?
I've heard that you can fit CBR600 internals, does anyone know how this was done?
and yes, I know the GSXR750 or a 1000 front end will cure all ills, but I would like things to look standard.
Thanks in advance
Dennis
DD
Sport 1100 carb
Offline Aaron D.
Re: 1100 Sport Carb MR1 forks- how to make better-er
« Reply #1 on: February 21, 2016, 02:14:13 PM »
They aren't cartridge forks, so you can't rebuild those. Just a damper rod fork.
Maybe bearings, and seals would do it, should you find the bushings have play. Mine don't as I approach 40,000 miles.
Offline Greenman
« Reply #2 on: February 21, 2016, 06:30:09 PM »
Yes, they are damper rod forks, but with that cartridge arrangement that doesn't allow you to fit emulators. someone must know something about these forks out there?
why, why why did they use these forks? was marzocchi dumping them.
DD
Sport 1100 carb
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #3 on: February 22, 2016, 04:06:10 PM »
They aren't that bad. They still make a huge upgrade to any tonti bike.
If you want fun, do it like dr john 26 years ago. One external shock outside mounted.
Paul
Daytona 1225, Stelvio 1151
Offline Aaron D.
« Reply #4 on: February 22, 2016, 05:04:37 PM »
I have to agree with Paul, they are pretty good for the time and I don't have any real problem with their performance.
Offline geodoc
« Reply #5 on: February 22, 2016, 05:56:55 PM »
I believe you're talking about the earlier Sport 1100 non-USD style with adjustable damping - compression on one side & rebound on the other. I fitted that front end on to a Tonti framed hot rod and was not at all pleased with the fork performance. In the end I sent them to Cogent Dynamics in North Carolina where he installed a cartridge set-up, tough still with the same compression on one side and rebound on the other as well as more appropriate springs. It was a huge improvement. I can't remember the exact cost, but it was not cheap. with hindsite, I should have gotten a CBR600 non-USD front end and been way ahead of the game and spent a lot less.
http://www.motocd.com/
As an aside, before they were modified and afterward too they had a clunk that drove me nuts coming from the fork internals. I probably had them apart a half a dozen times trying to figure it out. I did finally discover the problem. There is a bushing that is located at the bottom of the fork tube and secured with a circlip. This bushing had some slop in it that allowed it to move up & down about .100" with the fork action. I ended up using locktite to bond the bushing to the fork and that was the end of the clunk.
George
« Last Edit: February 22, 2016, 06:01:33 PM by geodoc »
« Reply #6 on: February 22, 2016, 06:18:48 PM »
For mine:
-WP springs
-10wt oil
-lowered 20mm
I'm pretty happy with the forks on the Sport 1100, and would love to have them on my V7 Special, too !!!
(just need some custom billet triple clamps   :evil: )
Offline Petrus Rocks
« Reply #7 on: February 24, 2016, 12:09:59 PM »
If they are damper rod forks you should be able to install emulators.  My guess is the adjustments would need to be removed.  They are a significant improvement.  You could check with race tech about fitment.  There are emulators out there that are less expensive than race tech's.
Offline Murray
« Reply #8 on: February 24, 2016, 12:48:02 PM »
WP were making slightly heavier springs are they still are NFI, Been damper rod forks the oil is worked hard and needs to be changed regularly which is suspect most people don't do. Their biggest problem IMO is the sheer weight of the front wheel. So depending on how deep your pockets are you may be able to find a marchseni off a late model ducati to fit.
« Reply #9 on: February 24, 2016, 12:58:43 PM »
Or, a Dymag.  But they're rare as hen's teeth!
