Author Topic: 01 EV-Any Problem going from 140/80-17 to 130/90-17?  (Read 5611 times)
Offline RayB
« on: February 23, 2016, 12:28:44 PM »
Wondering if anyone who has actually used a 130/90-17 rear in lieu of the specified 140/80-17 on an EV has had any problems.  Also, have you changed the front to a different size?
Right now I have a 100/90-18 front that I like instead of the spec 110/90-18...easier turn-in.
Current shoes are ME880 F&R, thinking of going to Shinko 230 Tourmasters
01 EV
82 BMW R100
Re: 01 EV-Any Problem going from 140/80-17 to 130/90-17?
« Reply #1 on: February 23, 2016, 12:41:54 PM »
The widest rim width for a 130/90-17 is 3.5".  I believe your rear rim is wider than that.  You could put a 150/70 rear tire on and that would lower your overall gearing by 250 rpm.
I have a bike w/a 3.5" x 17" rear rim  that started w/a 150/70 rear tire that was geared too low for my liking.  1st I put on a 140/80 rear and then a 130/90 rear and that changed the gearing 500 rpm, the equivalent of another gear.
I believe the earlier EVs have 3.5" rear rims but yours is wider.
« Last Edit: February 23, 2016, 09:46:13 PM by Arizona Wayne »
« Reply #2 on: February 23, 2016, 12:43:56 PM »
A 150 won't fit an 01. 140 barely fits. Many go to the 130 on the 98 - 01 Californias.
« Reply #3 on: February 23, 2016, 12:45:41 PM »
 Think the rim width on my '01 Jackal is the same , have been running a 130 for years , better turn in .
« Last Edit: February 23, 2016, 12:52:52 PM by oldbike54 »
« Reply #4 on: February 23, 2016, 12:55:09 PM »
There is very little tire width difference between a 140-150 tire.  It varies a little from 1 design tire to another also.   I've been studying these tire dimensions for over 15 years.
Offline RayB
« Reply #5 on: February 23, 2016, 12:55:25 PM »
Nope. Rear rim size is 3.50
Dusty: What size front do you run with 130/90 on the rear?
01 EV
82 BMW R100
« Reply #6 on: February 23, 2016, 01:03:18 PM »
 Right now the stock 110 , but have also used the 100 . Actually , the effects of running a 130 on the rear has a greater effect than running a 100 on the front .
« Reply #7 on: February 23, 2016, 01:13:03 PM »
I ran a 130 on the rear of my Jackal, and kept the stock 110 up front.
Ironically I went from a 150 to a 140 on the rear of the Sportster (and it was a noticeable difference, it broke over into the turns quicker), though even more ironically I went from a 100 to a 110 up front (but I balanced that effect by raising the forks in the trees slightly and raising the rear).
In all cases I'm talking Metzelers, including ME 88, ME880, and ME888.
Offline RayB
« Reply #8 on: February 23, 2016, 01:21:26 PM »
Thanks all.
01 EV
82 BMW R100
« Reply #9 on: February 23, 2016, 01:33:45 PM »
  Ray , just noticed that you asked about running a 90 aspect ratio tire . I also mounted a 130/90 rear, make sure that none of your wiring is hanging low , don't ask me how I know  :rolleyes:
Offline RayB
« Reply #10 on: February 23, 2016, 01:49:15 PM »
Did you end up moving he wiring or just make it high and tite?
01 EV
82 BMW R100
« Reply #11 on: February 23, 2016, 01:59:22 PM »
 Moved it temporarily , although at my next tire change will try to place it back to stock . The whole problem may well have been coincidental , haven't checked as well as I should have .
Online Vagrant
« Reply #12 on: February 23, 2016, 06:42:22 PM »
130/90 work fine. some 140's will rub. I did just buy the Shinko in stock sizes but won't get them on for a few weeks. I tried a 120 on the front once but it is a slower turn in. 2001 EV.
on the new V7 I just might go to the 130/90 rear next time instead of the 130/80. then use the 100 on the front of both. that way I will only need one set for both bikes.
« Reply #13 on: February 23, 2016, 09:51:59 PM »
If your V7 has a 17" rear rim I went from a 130/80 to a 130/90-17 on my 750 Breva and it works fine and lowered my rpms by 200 in top gear.   That's why I made the switch + so I had more tire choices.  Have a Shinko touring tire on there now.
Offline BillinPA
« Reply #14 on: February 24, 2016, 05:33:28 AM »
On my 2001/EV I have used more 130/tires than 140. Work well!!!
« Reply #15 on: February 24, 2016, 12:47:05 PM »
Which bike was it that Vasco used to be so emphatic about that a smaller tire worked so much better than the stock size?
