Author Topic: PSA, just in case  (Read 4863 times)
PSA, just in case
« on: February 23, 2016, 04:23:09 PM »
With all the talk about batteries, voltage and what does what, when and how, please remember:
When you are fiddling with the bike's battery, if you want to disconnect it for any reason...
1. Ground (negative - ) cable off FIRST!
When reconnecting:
1. Positive (+) first
2. Ground (negative - ) last
Back to our regularly scheduled voltage regulator and battery "discussion".
Even a motorcycle battery can become a welder.
Re: PSA, just in case
« Reply #1 on: February 23, 2016, 04:56:17 PM »
Good advice, something we do often forget!
In the old days it might have welded your wrench to the frame, now I think it can fry an ECU as well.
« Reply #2 on: February 23, 2016, 05:16:57 PM »
Wise words indeed N.P.
I have been asked "why?" before. Not a stupid question if you just don't know or understand why.
Offline thepittsburghguzzi
« Reply #3 on: February 23, 2016, 09:18:09 PM »
It's kind of funny to see "NEGATIVE" in bright red, as opposed to black :P
But for real, solid advice, and always worth reminding people!  :whip2:
2012 V7 Classic - Scarlet
1979 KZ750 Twin - Copper
-Paul
« Reply #4 on: February 23, 2016, 09:41:14 PM »
Is the negative one, the one with the hose clamp?
Todd.
Offline JeffOlson
« Reply #5 on: February 24, 2016, 12:04:25 PM »
Of course, just to confuse matters, on my Norge, positive is red, and negative is black.  :wink:
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline MGPilot
« Reply #6 on: February 24, 2016, 12:10:39 PM »
Reconnecting - Why positive first?
2014 Morgan Three Wheeler
« Reply #7 on: February 24, 2016, 12:25:21 PM »
 Positive first because with the negative disconnected there is no chance of your wrench arcing to the frame or any other short hapening.  Then once it is connected, go ahead and do the ground.  Since the wrench touching the frame is nothing more than an accidental ground and you were grounding anyway, no problem.
 Be careful with some older bikes, especially european.  Some used a positive ground.
« Reply #8 on: February 24, 2016, 12:33:00 PM »
Positive first because with the negative disconnected there is no chance of your wrench arcing to the frame or any other short happening.   Be careful with some older bikes, especially european.  Some used a positive ground.
The original Mini had positive earth. Could be changed by reflashing the generator. Not sure why BMC did that. Must have been a reason.
Anyone know?
Offline nc43bsa
« Reply #9 on: February 24, 2016, 12:42:51 PM »
Anyone know?
I was told it was because the negative ions generated by the charging battery reacted with the positive wires.  It was preferable for the corrosion to be distributed along the chassis (positive) rather than the wiring harness.
1990 MilleGT
« Reply #10 on: February 24, 2016, 12:45:17 PM »
That is probably the best way to do it, any electrical engineers want to comment? Ha!
Austin Healey and many Lucas systems use Pos ground which causes practical problems in the "modern"
era.
 The British car and bike industry , along with Chrysler used pos ground
Anyone know?
 So the 'lectricity could run backwards  :rolleyes: Seriously , seems like I read somewhere that it allowed for some savings in copper .
« Reply #11 on: February 24, 2016, 12:49:21 PM »
That sounds about right dusty! :grin:
kirby1923
« Reply #12 on: February 24, 2016, 12:50:38 PM »
 :1: Over simplified but on the mark.
« Reply #13 on: February 24, 2016, 01:02:43 PM »
 We are discussing an industry based largely in the English Midlands , ans area famous for being , er , frugal  :evil:
