Author Topic: This is why 3D printing is getting popular  (Read 3270 times)
« on: February 23, 2016, 06:34:08 PM »
At $249.00 for an original Le Mans switch getting the parts made in a 3D printer makes a lot of sense. I just need to take one apart and measure it and transfer to AutoCAD and have my son spit one out. I don't think the wiring connections are very complex.
http://www.ebay.ca/itm/NOS-THUMB-SWITCH-MOTO-GUZZI-850-T3-CALIFORNIA-LAPD-TONTI-LEMANS-B-G-7503-/322017226914?hash=item4af9b8f0a2:i:322017226914&vxp=mtr
« Last Edit: February 23, 2016, 06:34:34 PM by canuck750 »
Re: This is why 3D printing is getting popular
« Reply #1 on: February 23, 2016, 06:59:37 PM »
Just because he's asking $249, doesn't mean he'll get it.  :wink: I gave away one of those switches that still functioned, but had new (wrong color) wires spliced on.
Offline boatdetective
« Reply #2 on: February 23, 2016, 07:28:24 PM »
Maybe I'm wrong- but all the 3D stuff I've seen has been "prototype" pieces in a very brittle plastic with a finish that leaves something to be desired. I don't quite get it.  It's certainly not anything you could use in the field.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
« Reply #3 on: February 23, 2016, 07:36:24 PM »
There are several choices of plastic for the extrusion type printers, including ABS and Nylon, so parts can be quite durable.  I'm using parts printed from ABS to make housings for a couple of the CDI units and regulators I sell, and it allows me to keep the price lower than if I had to hand fabricate them.  Higher volume production, even so called "low volume molding" is out of the question when I'm selling maybe 25 of a particular product per year.  You can see the layers in the surface finish, but with ABS you can use acetone to "solvent polish" the surfaces to smooth them out.  It also takes paint very well.
Offline nobleswood
« Reply #4 on: February 23, 2016, 08:47:37 PM »
At my local Microcenter on Saturday the salesman was showing me some of the 3D scanners he had. That even takes away having to draw a switch up in AutoCad. Just need to find someone, who has a scanner to rent the time from, and then have the file sent over to a Printer.
Amazing stuff!
2013 1200 8v Griso
« Reply #5 on: February 23, 2016, 09:02:50 PM »
My son made me up some CEV headlight plastic plugs for the V7 Sport headlight, they are very nice reproductions and the plastic is not brittle. There are layering lines but this was on an earlier machine he had, the new one is a much finer resolution.
« Reply #6 on: February 23, 2016, 09:39:38 PM »
This is the future, full size 3D printed bodywork
« Reply #7 on: February 23, 2016, 09:57:26 PM »
And of course printed parts can be used in lost wax type casting, so things that used to be very labor intensive to prototype, like boat propellers, can be printed and used as the casting pattern.
Offline mtiberio
    • TiberioRacing
« Reply #8 on: February 24, 2016, 06:33:38 AM »
they 3-D print the "iron man" suit parts for the Iron Man movies. Those parts look shiney enough...
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #9 on: February 24, 2016, 06:39:08 AM »
When I first saw a computer hooked to a milling machine, I thought, "That *is* the future of machining." Old timers he hawed about it, but it was true.
3D printing is at about the same stage as CNC machines when they first became available. They're not there, yet.. but they will be, eventually.
Offline tris
« Reply #10 on: February 24, 2016, 06:46:24 AM »
I went to this place a while back. http://www.the-mtc.org/technologies
The ball you can see is 3D printed titanium and ... bounces like a ball. They also had some 3D printed chain mail
Re size, they're gearing up to hang 2 robots from a gantry that's big enough to 3D print something a big as a car
I agree with Chuck, additive manufacturing is going to be the next big manufacturing technology without a shadow of doubt
PS
When I first saw a CNC lathe screw cutting a 3" thread at full turning speed and the carriage go hurtling off towards the chuck I thought ..... there's going to be an almighty crash in a moment  :wink:
« Last Edit: February 24, 2016, 06:51:52 AM by tris »
1993 TW125 "POS" - Resting
