Author Topic: Would you buy an 8 valve with flat tappets?  (Read 31733 times)
Offline Travlr
« on: February 24, 2016, 12:42:00 PM »
There are some 8V flat tappet bikes I like better than the later roller models.
A Griso SE for instance.
But I'm reluctant to purchase a flat tappet bike for obvious reasons.
Just gathering some thoughts on rather to purchase and what the cost would be to convert.
Mike
1984 LeMans 3 Cafe Racer
1977 BMW R100S
Offline H-E-ROSS
Re: Would you buy an 8 valve with flat tappets?
« Reply #1 on: February 24, 2016, 01:04:39 PM »
Just curious, whats not to like about a SE? color or spokes?
« Reply #2 on: February 24, 2016, 01:51:57 PM »
In a word: NO.
If I were to buy a Griso, it would be an 1100 (2V(4V) motor), or 8V that came from the factory with rollers.
Same goes for a Norge, 2V(4V) or 8V roller.
Offline Jdcooper
« Reply #3 on: February 24, 2016, 02:14:51 PM »
Here is a cam box from my Stelvio 8V with about 21K miles.
The cam face looked like this:
If you buy it, consider a few things:
-   they will ALL fail eventually
-   sometimes MG will comp you the kit (which runs about $1400 retail)
-   the labor goes at 12 or13 hours.
I would bargain a lower price using these facts. Good luck, Mate.
« Reply #4 on: February 24, 2016, 02:23:51 PM »
In a word: NO.
 :1:
In two words.  HELL no.
« Reply #5 on: February 24, 2016, 02:25:37 PM »
I think he's saying he LIKES the early SE.  Probably the Tenni Green from 2011-2012
Offline H-E-ROSS
« Reply #6 on: February 24, 2016, 02:31:08 PM »
I liked it too, until I started reading up on this problem. I ended up buying a '13 SE to avoid the headache never mind the expense.
Offline Trogladyte
  • Location: South London - home of the world's best football team.
« Reply #7 on: February 24, 2016, 02:32:36 PM »
No.
NEVER.
Not in a billion years. I'd rather gnaw my own foot off.
My Griso had FIVE sets of cam gear, which lasted on average a few thousand miles. All on warranty, but it was still a right royal painus in the anus. Never again. Rollers all the way.
« Reply #8 on: February 24, 2016, 02:34:56 PM »
The asking price would have to be low enough that with adding in the price of the roller retrofit kit, it would still be a deal...of course, if one isn't mechanically inclined, then the cost of the install labor must be added in, as well....I've seen some nice used MG bikes for sale that could be rollerized (by the owner) and still be less money than used factory used models....I would use the cost of the appropriate roller kit as a bargaining chip in price negotiations...an uniformed buyer might pay the asking price up front, but the knowledgeable Guzzi fan should be armed with the facts...IMHO
beetle
« Reply #9 on: February 24, 2016, 02:43:13 PM »
I would. Two caveats however:
Pre purchase inspection required by a dealer of your choice. If the tappets look like this:
Plus there is a service history? Say yes with the cost of the kit and labour factored in.
If they look like this:
Run away.
Offline Travlr
« Reply #10 on: February 24, 2016, 02:58:17 PM »
That is correct!
Mike
1977 BMW R100S
« Reply #11 on: February 24, 2016, 03:07:16 PM »
In a word: NO.
 So , this (2V(4V) motor , only imported to Pennsylvania ?  :huh:
Offline rboe
« Reply #12 on: February 24, 2016, 03:07:45 PM »
We should talk......  :grin:
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline Greenman
« Reply #13 on: February 24, 2016, 03:57:46 PM »
There is a griso SE for sale here in NZ with tappets that are bad. It's on the local trademe website. the owner is starting bidding at $1000.
I'm almost keen to take the risk that the damage is only in the heads, but he is saying that tappets were fine one day, and then a month later they were not. So I take that as the engine damage is terminal.
Everything else is as new..
DD
Sport 1100 carb
Offline Cool Runnings
« Reply #14 on: February 24, 2016, 04:15:50 PM »
Tell him the bottom end is most likely gone, offer him $500 cash.
You could always part it out.  :boozing:
Offline Perazzimx14
« Reply #15 on: February 24, 2016, 04:32:50 PM »
Quite honestly I wouldn't buy ANY 4 valve per cylinder Guzzi.
Offline Clancy
« Reply #16 on: February 24, 2016, 05:05:57 PM »
What Beetle says.
Low kms, low price and factor in the cost to have it rollered.
Cheers
Craig
Offline tazio
« Reply #17 on: February 24, 2016, 06:36:28 PM »
WOW. Are the hours in fact that high?
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Offline dxhall
« Reply #18 on: February 24, 2016, 06:44:31 PM »
And rollers started when?
Offline rboe
« Reply #19 on: February 24, 2016, 06:49:33 PM »
Installed mid - 2012 production.
Labor should be closer to 4 hours.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline tazio
« Reply #20 on: February 24, 2016, 06:58:58 PM »
« Reply #21 on: February 24, 2016, 07:09:20 PM »
I charge 3-4hrs, any more is gouging.
Road Mike's old Stelvio today after dialing it all in, turned out nice, fueling on idle had to do a -20 for it to take throttle w/o a bog.      Real nice 2010 Rollerized w/tune in ECU for pipe
Offline poorBob
« Reply #22 on: February 24, 2016, 07:12:54 PM »
Mine is next!
Offline MGrego
« Reply #23 on: February 24, 2016, 07:13:05 PM »
Yes, however, --- Caveat Emptor
Better understand the problem and figure the cost of rollerization into the purchase price !
Offline Perazzimx14
« Reply #24 on: February 24, 2016, 07:15:10 PM »
In Pennsylvania its commonly referred to as the "6V".
« Reply #25 on: February 24, 2016, 07:43:33 PM »
I just hate the inconsistency  that most people call the 2 valve per cylinder motor 2V and the 4 valve per cylinder motor 8V.    It should be 2V and 4V or 4V and 8V.
Yes, sometimes I do have CDO (that's OCD, but, with the letters in alphabetical order as they should be).
 :grin:
That is a lot more clear!     Or, just call it a 6V  :wink:
« Last Edit: February 24, 2016, 07:46:12 PM by jas67 »
« Reply #26 on: February 24, 2016, 07:48:16 PM »
 :grin:
 I figured one 2 valve head and one 4 valve head  :huh:
« Reply #27 on: February 24, 2016, 08:32:03 PM »
Call it an 'in head cam' if you can't understand the name.  :rolleyes:
If you are interested, Beetle covered it.
By all means, consider it. As he mentioned, if it has been grinding away a lot of metal, run away.
If it is fairly clean, then factor in a recall kit.
The amount of labor varies. If it is an A or B kit, probably close to 3 hours, maybe 4. If it is a C kit (don't think it is), it is a LOT more time. Maybe 8 to 10 hours.
Offline Nic in Western NYS
« Reply #28 on: February 24, 2016, 09:35:12 PM »
Come to think of it, there is no ambiguity if 2V and 8V are used as terms.  4V is the ambiguous term.  I say to heck with consistency and scrap the ambiguous term.  I also don't think the earlier generation 8V engines should be lumped into the mess.  They didn't have fatal flaws as far as I know.
'04 Ducati ST4sABS
Moto
« Reply #29 on: February 24, 2016, 09:40:07 PM »
Long ago, 2 valve vs. 8 valve was my suggestion for unambiguous terminology. I took some flack for it, notably from Down Under.
You're all welcome.
Moto
P.S. I would be hesitant to buy any of the current generation of 8v engines, unless I knew the one I was interested in was fitted with rollers at the factory. Some compromised flat tappet engines have probably been rollerized by now, with lingering problems in the bottom end. At least that's how I interpret what more knowledgeable people than I have posted.
« Last Edit: February 24, 2016, 09:47:21 PM by Moto »
