Author Topic: Aerospace lock nuts - work question  (Read 7500 times)
Offline tris
« on: February 25, 2016, 04:56:32 AM »
Morning all
I'm trying to track some 12 point flanged lock nuts down and our engineering department want to know the ISO/ASME/BS/DIN standard that applies.
I'm struggling though as I suspect that they are propriety items and aren't made to an international standard.
So what to you aerospace types call these please
Cheers
Tris
1993 TW125 "POS" - Resting
Offline clubman
Re: Aerospace lock nuts - work question
« Reply #1 on: February 25, 2016, 05:41:51 AM »
McMaster-Carr has them listed as "High-Torque 12-Point Flange Nuts" available in crome-moly or A286 stainless. They don't however list engineering specs for these nuts, as they do some others. Give them a call, 404 346 7000, and they can probably come up with a manufac. spec. sheet. Good luck.
« Reply #2 on: February 25, 2016, 05:52:46 AM »
I've seen them on helicopters in high temp areas, but I don't know what they're called, either.
Offline tris
« Reply #3 on: February 25, 2016, 05:57:27 AM »
CM
Cheers I'll take a look but if they're not showing a spec could be because there isn't one!!
PS
I'm based in the UK so don't use McMaster - could you shoot a linky over please?
CinI
That'll be them.
We use the to hold the top and bottom halves of an industrial gas turbine together - so hot too!
Somebody will know what they called
Offline Dean Rose
    • Twin Valley Riders
« Reply #4 on: February 25, 2016, 06:02:17 AM »
CM
PS
CinI
That'll be them.
http://www.mcmaster.com/#
Magnolia '02 EV
Sophia '06 Breva 1100
Offline tris
« Reply #5 on: February 25, 2016, 06:42:41 AM »
I like McMaster Carr - we don't have anything close to that over here  :cry
Online John A
« Reply #6 on: February 25, 2016, 07:47:59 AM »
We always called them jet nuts or heat nuts. Try Rolls Royce, they should have published specs. Pratt&Whitney too. They may not be real forthcoming on the specs, being proprietary but maybe an aftermarket aviation supply will say if an item meets specs, they should be able to furnish those.
« Last Edit: February 25, 2016, 07:56:59 AM by John A »
Offline Groover
    • Scooteropolis
« Reply #7 on: February 25, 2016, 08:08:29 AM »
Looks like clubman nailed it:
Here is a PDF with info and website info:
http://www.afsrsimmonds.net/pdf/M3k6913_Flier_DHE_Final.pdf
They're in France though I think.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Online John A
« Reply #8 on: February 25, 2016, 08:24:56 AM »
Groover nailed it!
Offline dsrdave
« Reply #9 on: February 25, 2016, 08:35:47 AM »
We always called them jet nuts.  Used them a  lot on the race car.  Many racing suppliers (pegasus an such) will stock them at a fair price and may have specs avail.
Offline tris
« Reply #10 on: February 25, 2016, 08:44:02 AM »
Groover nailed it!
YEP - Groover nailed it. :bow: :bow: :bow: :bow:
I knew of Simmonds but hadn't found that spec and specifically ISO 8788-2000 Annex E
All personnel may now stand down and thanks for all your input
Tris
Offline Groover
    • Scooteropolis
« Reply #11 on: February 25, 2016, 08:54:34 AM »
I can't take any of this credit! All I did was Google what Clubman defined as the name of the nut, so Clubman gets the points!
1980 Vespa SI Moped
Online acogoff
« Reply #12 on: February 25, 2016, 09:31:49 AM »
     Looks like the NAS 1804 series similar to what the old Hillers had holding a lot of their transmission component together
I think the 12 point is referred to as "double hexagon". Handy little nuts they are space wise. Solve a lot of tight engineering problem areas.
Marshall County Minnesota USA
Offline lucky phil
« Reply #13 on: February 25, 2016, 02:34:00 PM »
Yes looks like an NAS flanged multihex nut and probably falls under a MIL spec somewhere.
Seen literally millions in my career on everything from wheel hubs to turbine and compressor cases.
Finishes differ from a "black" finish to a silvery white depending mainly on the environment it has to deal with.
Ciao
Offline tris
« Reply #14 on: February 25, 2016, 04:22:42 PM »
Cheers all
I'm looking for the metric version Is there any metric NAS or are they all inch sizes?
Online RinkRat II
  • Lake Powell AZ
« Reply #15 on: February 25, 2016, 05:33:31 PM »
 Hey Tris .
    ARP  here in America has what your looking for and they may have distribution in Europe
    http://arp-bolts.com/
 Paul B :boozing:
HardAspie
« Reply #16 on: February 25, 2016, 05:43:44 PM »
I have seen advertised 12 point wrenches to get a very good grab on these things. I think that for their size they can accept large set torque.
« Reply #17 on: February 25, 2016, 08:14:39 PM »
Cheers all
Yep, Eurocopter uses them..metric sizes.
Offline mrrick
« Reply #18 on: February 25, 2016, 09:13:18 PM »
Metric.  In Belgium.
http://www.anemo.eu/node/1075
Offline mtiberio
    • TiberioRacing
« Reply #19 on: February 26, 2016, 06:13:30 AM »
carrillo rods came with "SPS-Carr" nuts which looked like that
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline mtiberio
    • TiberioRacing
« Reply #20 on: February 26, 2016, 06:19:36 AM »
Online John A
« Reply #21 on: February 26, 2016, 07:45:26 AM »
On MBB (Eurocopter) BO 105 helicopters the engine to main transmission driveshaft bolts were "on condition " but changed to one time use. They fit the Guzzi crown wheel perfectly. Nice bolts, ground threads, serial numbered and all that. The rest of the helicopter is metric, with the exception of the engine, Allison C20, now Rolls Royce. A lot of very nice metric hardware, wish I would have pocketed more"work order residue"
« Last Edit: February 26, 2016, 07:59:26 AM by John A »
« Reply #22 on: February 26, 2016, 10:52:51 AM »
Nice hardware, all right. I'll bet they cost enough to make the suspenders wearing Guzzi Guy drop his pipe.  :smiley:
Online John A
« Reply #23 on: February 26, 2016, 02:19:31 PM »
And swallow his snoose at the same time!
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #24 on: February 26, 2016, 03:14:33 PM »
Didn't Triumph use these type of nuts to hold the barrels on to the crankcase?  I've got a few flowing around here somewhere.
Offline RayB
« Reply #25 on: February 26, 2016, 04:02:14 PM »
.....and the later BSA A65s but without the sleeve on top
01 EV
82 BMW R100
« Reply #26 on: February 26, 2016, 06:18:11 PM »
Probably not quite this quality..
or price. :smiley:
Online John A
« Reply #27 on: February 26, 2016, 07:38:58 PM »
I think those driveshaft bolts were only about 300 bones apiece.
Offline jabberwocky
« Reply #28 on: February 26, 2016, 08:56:51 PM »
Some later airheads used these on the final drive to swing arm studs, I think 10mm threads.
HardAspie
« Reply #29 on: February 26, 2016, 08:58:29 PM »
Aviation certification and product liability adds a bit to the price.
