Author Topic: 3205AC3 bearing source?  (Read 2581 times)
« on: March 15, 2016, 03:39:16 PM »
Sorry if this is a rerun of earlier threads. I used "search" and since I rarely work on "modern" Guzzis, have only paid occasional attention to previous threads on the subject.
I have Nick D's EV torn apart for clutch replacement and started on replacing the leaking transmission output shaft seal a few minutes ago. One washer for the speedo drive is missing (well, not completely, it's now filings) and I suspect that it's responsible for damage to both speedo drive gears and for destroying the plastic cage of the output shaft bearing.  :sad: The front clutch shaft bearing (also plastic caged) feels "rough" when the shaft is spun.
So, I'll be needing new bearings obviously. Where to source them? HMB Guzzi offers a bearing marked "3205B" with "flexible cages": http://hmb-guzzi.de/Caged-ball-bearing-input-output-shafts-5-speed-gearbox
I found some 3205AC3 bearings on eBay as well: http://tinyurl.com/SKF-3205AC3-bearing
Other sources would be appreciated.
Offline Curtis Harper
    • Harpers Moto Guzzi
Re: 3205AC3 bearing source?
« Reply #1 on: March 15, 2016, 03:57:01 PM »
Guzzi dealers are usually a great place to start.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
« Reply #2 on: March 15, 2016, 03:58:54 PM »
How many you want Charlie? I can get the 14 ball per race, serpentine steel cage AC3's locally very easily and they won't cost a fortune to ship.
Offline Groover
    • Scooteropolis
« Reply #3 on: March 15, 2016, 04:06:15 PM »
Maybe check with these guys of other suggestions don't pan out:
https://www.jsbgreatbearings.com/
Good luck.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #4 on: March 15, 2016, 04:26:45 PM »
PM'ed you.
