Author Topic: Flywheel timing marks, T3  (Read 5346 times)
Offline jabberwocky
« on: March 17, 2016, 07:42:04 PM »
About a year ago, I picked up, on ebay, a nice flywheel for my T3. I can't remember what bike it came from, but it's from something much newer than a T3. It has some little protrusions, which must be for some kind of crank position sensor. It has a D and an S at TDC, but no other timing marks. The flywheel is now on the engine, transmission bolted up, and I rigged a dead stop to dial in exact TDC with a degree wheel. The D and the S are dead on. While I have the degree wheel and pointer set up, I'd like to make some marks for static timing, idle advance, and max advance, so when I get it running again, I can dial it right in. Can anyone tell me where the marks should be, stock or not? My distributor is a T3 unit, the only non stock thing about this engine is 89mm bore and pistons. Thanks everybody.
Offline acogoff
Re: Flywheel timing marks, T3
« Reply #1 on: March 17, 2016, 09:18:33 PM »
    If'n you have a T3 dizzy spring set up, your static timing is 2 degrees BTDC and your advanced is 31 degrees more at 33 degrees before top dead center.
Marshall County Minnesota USA
« Reply #2 on: March 17, 2016, 09:54:19 PM »
  The D is for "Dis side" the side with the window you are sighting through.
  The S is for S'not dis side.
Offline Two Checks
« Reply #3 on: March 18, 2016, 02:40:01 AM »
'Sa lefta side and Datsa da right side.
1987 1000 SPII "Il Duce' II"
Offline Stevex
« Reply #4 on: March 18, 2016, 11:10:48 AM »
My lightened flywheel came without markings, so I put an L and an R on it...foolproof   :azn:
« Last Edit: March 18, 2016, 11:11:46 AM by Stevex »
Offline jabberwocky
« Reply #5 on: March 18, 2016, 04:48:14 PM »
Thanks, that's what I needed!
« Reply #6 on: March 18, 2016, 06:07:13 PM »
 Now Guido won't be able to set your timing for you.
