Author Topic: carb float valve seat repair  (Read 3393 times)
Offline oranges3
  • "this amp goes to eleven..." Nigel Tufnel, Spinal Tap
« on: March 20, 2016, 06:28:22 AM »
hey guys...
i have a triumph triple with keihin CVK36 carbs...
center carb started leaking...
checked float level and all is good.
replace needle valves and found that the seat has a small scratch on the side and is catching the needle, not allowing it to seat.
the needle seat is pressed in so them cannot be replaced...
does anyone have experience fixing this type of problem?
i was think of polishing the sides with valve lapping compound to clean up the scratch...
please oh wise ones, bestow upon me the knowledge obtained through frugality!
2012 ducati diavel
1995 Triumph Speed Triple
1998 Triumph Thunderbird Sport
2004 V11 Cafe Sport
1999 Confederate America GT
2018 Motus MST
2007 griso
1986 kawasaki ninja 600r
183 Honda VT500 Ascot (son's bike)
redrider
Re: carb float valve seat repair
« Reply #1 on: March 20, 2016, 07:51:15 AM »
Replace the carb. It is the Japanese Way. The black screw on top Amals, Mk II Concentrics worked better in a previous life.
« Reply #2 on: March 20, 2016, 07:58:09 AM »
 Some pressed in seats can be very carefully drilled out and replaced . Never had much luck polishing out a scratch in one , always just buggered them up worse . YMMV , and worth a try .
Offline lucian
« Reply #3 on: March 20, 2016, 08:16:28 AM »
I once chucked a  knitting needle in a battery drill and redressed a needle valve seat with fine rubbing compound.  Stopped the leaking. Just dress the tip of the knitting needle to match the tip of your carb needle and go to it. Valve lapping compound may be a little too aggressive on soft aluminum..
