I always assumed that they weren't meant to be left on all of the time, but installed only when needed. In any case, that's how I use mine.
Hi Luap, I'm a firm believer in Kurvy Girl. Yep, that's my source for angled valve stems.https://www.kurveygirl.com/shop/index.php?cPath=169No kidding, this is the place to get your valve stems. Now, for tube type tires...you are screwed.Peter Y.
Sudden tire deflation can occur when the centrifugal forces of the spinning tire cause the stem to deflect slightly. The cap end will be forced towards the rim. Honda "discovered" this after several "incidents" on the wing/barge. This led to the addition of that little stem support plastic thingy. Of course, I wonder about the forces acting on the stem valve for the straight type. At what point does the force overcome the spring? From there, only the stem cap keeps the air in. Soooo, make sure your caps have the seal in them. I have first hand experience on THAT one.
