Author Topic: 1000 sp gas cap key  (Read 5136 times)
nunzio
1000 sp gas cap key
« on: March 28, 2016, 01:30:59 PM »
I have a gas cap lock that will not open.
Should the ignition key also work on the gas cap key?
The number on the lock is 1581.
Anyone have one I can buy?
Any information is appreciated.
Thanks...Alan
Back story...I bought the 1000sp. then had surgery on both sholders and am now just getting ready to sell it,so, I would like to get the lock working.
I did not check to see if it worked when I bought it .(lesson learned)
Re: 1000 sp gas cap key
« Reply #1 on: March 28, 2016, 01:36:41 PM »
Gas cap lock should match ignition key.  Unless either lock has been changed.  Spray some WD40 in the stuck lock.
The key blank is Taylor F79-1 made for Fiat  :wink:  I got 1 for my CX100
« Last Edit: March 28, 2016, 02:03:48 PM by Arizona Wayne »
« Reply #2 on: March 28, 2016, 01:37:59 PM »
Should be the same as the fork lock also, on the neck.  Maybe ign was changed. Should be same as BMW blank used on airheads.
« Reply #3 on: March 28, 2016, 01:50:43 PM »
The fork lock should be a Neiman and different than the ignition and gas tank flap lock. At least it was on every Tonti I ever owned.
Alan: assuming that the ignition switch is the original, there should be a (very tiny) number stamped right next to the key slot. If that's the same as the gas tank flap lock number, then it should work. Maybe the lock is just dry and could use a little Lock-Ease squirted into it.
If you need a key cut to code 1581, these guys can do it: http://keys4classics.com/html/MotoGuzzi.html
Offline Groover
    • Scooteropolis
« Reply #4 on: March 28, 2016, 02:36:49 PM »
If it is indeed the correct key, try pushing down on the key while turning it to unlock. The rubber bumpers for the lid have hardened causing it to be not-so-cushy when trying to unlock it.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #5 on: March 28, 2016, 02:47:52 PM »
I'm not sure there was any standard about keys on older Tontis.  My Mille has three keys.  One for ignition, one for gas cap, and one for fork lock and seat.  I've heard of one that has four keys, and the fork lock and seat keys are not the same.  I believe that bike was bought new and has not had any locks replaced.
« Reply #6 on: March 28, 2016, 02:57:02 PM »
If you get a double sided key cut ask them to cut the ignition on one side and the tank cap on the other then you don't need two keys.
« Reply #7 on: March 28, 2016, 03:23:49 PM »
I didn't know any Guzzis had double sided keys, Roy.  My Mille has all single sided ones.
« Reply #8 on: March 28, 2016, 04:14:06 PM »
Sorry, I wasn't thinking old Guzzis, my EV and the VII Sport do
Your'e right the 84 Cali II and the Eldorado are single sided
« Reply #9 on: March 28, 2016, 04:30:12 PM »
Oh, no problem, I just wondered.  The idea is very interesting.  I wonder if I could get one double sided key made that fits the two Fords we have here.
« Reply #10 on: March 28, 2016, 04:43:54 PM »
Can you tell I haven't worked on that stuff in last 10yrs. I'm wrong and get those old models mixed up that's why I'm retiring. I'll have time to relearn on my own stuff. Having senior moments(short term memory) I shouldn't even be posting if I'm not sure. All I would have had to do is look in the garage.
Offline JoeW
    • The Guzzi Doctor
« Reply #11 on: March 28, 2016, 04:51:30 PM »
That bike should have the trap door over the gas cap. It's suppose to be the same key as the ignition. If you can't get it to work, gently pry up on the front edge of the cover, you'll bend the hinge a little, you can bend it back later. Now you should be able to use an 8mm or 5/16" open end and take out the 2 bolts and remove the cover. The tumbler is just held in with a snap ring. Pop out the tumbler, remove all the discs and the lock will open with any key that fits or a screw driver. How much for the bike?
« Last Edit: March 28, 2016, 04:52:07 PM by JoeW »
Joe Walano
« Reply #12 on: March 28, 2016, 04:54:14 PM »
Or take the lock to a good locksmith and have him make a key.
Offline JoeW
    • The Guzzi Doctor
« Reply #13 on: March 28, 2016, 04:59:42 PM »
I don't like locking gas caps or fork locks. I have "losethekeyofobia" One key per bike is enough.
Joe Walano
« Reply #14 on: March 28, 2016, 05:05:20 PM »
Not if they are chip keys
Ace Hardware made me a chip key for the Taurus for less than the Ford dealer wanted for just the blank.
« Last Edit: March 28, 2016, 05:09:59 PM by Kiwi_Roy »
« Reply #15 on: March 28, 2016, 05:49:15 PM »
One is a chip key and one is not, so I might be able to have a key cut for both, and program the chip for the one that needs it.  I'll have to check to see if the key blanks look the same.
 We bought a couple key blanks through eBay for something like $5 each, and had them cut at the local farm supply store where we couldn't get the guy to charge us anything, then programmed them ourselves according to the procedure in the manual.
Edit:  Nuts.  The key blanks aren't even close.
« Last Edit: March 28, 2016, 05:50:36 PM by Triple Jim »
Offline slopokes
« Reply #16 on: March 28, 2016, 06:26:58 PM »
if you live close to nyc I can come over with my 10lb sledge and get that cover off :boozing: what are you looking to get for the sp ????
Offline ccoli
  • What? Me Worry?
« Reply #17 on: March 28, 2016, 10:42:05 PM »
I have trouble getting my key all the way into the gas cap lock sometimes.  Have to wiggle and push to get it all the way down.
Wisconsin MGNOC Rep
« Reply #18 on: March 29, 2016, 07:23:33 AM »
That is what I did when I lost the key to the trap door on my SPIII.
« Reply #19 on: March 29, 2016, 08:13:33 AM »
If someone bought my bike they'd find a different key for every lock.  I like the idea of getting rid of the tumblers though.  I am going to do that this weekend (I never liked locking gas caps).  I may even do that to the seat lock as well, get rid of another key.
My first Honda did not have a key.  I converted it to a single circuit breaker that was 'hidden' under the seat.  Flip it on and go.  I may do that with the Guzzi one day.
nunzio
« Reply #20 on: March 29, 2016, 08:47:20 AM »
Thanks for the responses.  :thumb:
It is the lock on the tank flap.
I'm leaning toward the remove tumbler thing.
The 1000SP is a leaner sidecar rig with a trailer.
PM me if you want more information.
I'll put it in for sale forum in a week or so.
Thanks...Alan
