Author Topic: My Lemans SE project thread - update 2026 exhaust  (Read 322778 times)
Offline Old Jock
Re: My new Lemans SE project
« Reply #30 on: May 07, 2016, 03:35:13 AM »
Stealth job?
Looking forward to watching it take shape
« Reply #31 on: May 07, 2016, 08:58:08 AM »
 :popcorn:
Offline Stevex
« Reply #32 on: May 07, 2016, 12:27:12 PM »
Turin, you need to sort out your camera's focal / macro settings.
Offline Turin
« Reply #33 on: August 29, 2016, 10:13:40 PM »
Frames ready.
1985 Sidlow Guzzi
Offline Scud
« Reply #34 on: August 29, 2016, 10:22:26 PM »
Sweet!!  What paint did you use? and are you happy enough that you would use it again?
Looking forward to following along with the project.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline Turin
« Reply #35 on: August 29, 2016, 10:47:16 PM »
Powder coat. I suck at painting.
1985 Sidlow Guzzi
Offline Scud
« Reply #36 on: August 29, 2016, 11:09:58 PM »
I'm a fan of powdercoat too.
I should have been more specific - you mentioned paint on drivetrain. I assume you painted the engine, tranny, etc. That's what I was curious about.
2020 Yamaha TW200
Offline Turin
« Reply #37 on: August 29, 2016, 11:26:54 PM »
Oh, rustoleum 2X.
1985 Sidlow Guzzi
Offline Groover
    • Scooteropolis
« Reply #38 on: August 30, 2016, 07:29:41 AM »
If you get bored with the project, I'll take that engine  :azn:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #39 on: August 30, 2016, 08:56:46 AM »
Nice, thanks for posting
Jim
« Reply #40 on: August 30, 2016, 02:51:25 PM »
Need I say I really like project threads?  :smiley:  :popcorn:
« Reply #41 on: August 30, 2016, 03:35:49 PM »
With the frame painted that color.  What are doing the body work in? and are you keeping the swallow tail look?  Looks good so far.
Offline Turin
« Reply #42 on: August 30, 2016, 08:53:28 PM »
Swan tail.. check!  Solo seat only. Since it is an SE, the bodywork will be white with red accents.
Tom, did you ever hear this thing run back in the day?
« Last Edit: July 12, 2025, 04:55:46 PM by Turin »
1985 Sidlow Guzzi
« Reply #43 on: August 31, 2016, 02:23:34 PM »
I have a '87 SE with 16" front wheel.  It has a Bub exhaust system on it.  Sounds pretty good.
Biggest problem, I had was with the right accelerator pump.  The factory setting had it squirting too much gas.  I found this out by chance.  Took awhile to find this out.  Rebuilt the carbs 3 times.  Checked the complete ignition system 4 times.  I really wanted to punch Guido in the face.
The other problem, that has plagued this model is the triple trees.  Check for cracks.  Not sure why.  Maybe the metal used in them or Guido tried to save some pennies for the parts.  This is/was the problem that showed with the 16" wheel up front. IMO.  Anyone can correct.
I don't have the 16" handling problem that was with most others.  My '89 LeMans V has the 18" front wheel otherwise the same bike as the '87 LeMans IV SE.
« Reply #44 on: August 31, 2016, 02:53:36 PM »
First I've heard of this "plague". <shrug>
« Reply #45 on: August 31, 2016, 05:49:28 PM »
The perceived problem that people have said with the SE was the 16" wheel.  Turns out the triple trees were the problem.
« Reply #46 on: August 31, 2016, 07:42:37 PM »
The only triple tree "issue" I've heard of was the '85 version vs. later ones. In '86 they changed the offset, increasing trail and slowing the steering a bit. The material changed too - from nicely cast aluminum to roughly cast steel/iron. Never heard of either cracking.
The later type was supplied as an "update" kit to anyone with an '85 that wanted it.
Edit: Guzziology agrees with the above and says that "Later ('86-on) bikes again had aluminum clamps but of the revised dimensions".
« Last Edit: August 31, 2016, 07:47:48 PM by Antietam Classic Cycle »
« Reply #47 on: September 01, 2016, 03:40:08 PM »
Maybe that's the "problem" for the 16" wheel and by the time it was corrected, the "bad handling" label got tied to the bike.
« Reply #48 on: September 01, 2016, 04:10:22 PM »
I got the triple trees covered.
Very nice! :thumb:
Offline Turin
« Reply #49 on: September 17, 2016, 12:52:39 AM »
« Last Edit: October 15, 2017, 04:50:42 PM by Turin »
1985 Sidlow Guzzi
Offline Turin
« Reply #50 on: October 15, 2016, 09:33:39 PM »
powder coated factory 16" & 18" wheels. She will have no problem stopping!
« Last Edit: October 15, 2016, 09:35:18 PM by Turin »
1985 Sidlow Guzzi
Offline Old Jock
« Reply #51 on: October 16, 2016, 04:36:35 AM »
Good grief what size of rotors are these?   :grin:
I know the 16" wheel will make them appear even bigger, but when I look at my 320s on an 18" wheel they look miniscule compared with these
Can you get the caliper on and off without removing the rotor? Might be tight once lines are installed
Watching with interest........... .........nice work Turin
Offline dblue
« Reply #52 on: October 16, 2016, 08:42:29 AM »
 Is that the Dave's Cycle racer?
David Blue
dfblue46@outlook.com
937-210-8721
Offline Turin
« Reply #53 on: October 16, 2016, 10:43:20 AM »
This is  the Daves Cycle racebike.
 The rotors are NOS 300mm that were part of the old upgrade kit for the 18" wheel conversion. http://www.dropbears.com/s/sda/p62.htm
Calipers are Harrison billet 6 piston that I scored off of E-bay several years ago.
« Last Edit: October 16, 2016, 10:54:15 AM by Turin »
1985 Sidlow Guzzi
Offline dblue
« Reply #54 on: October 16, 2016, 11:25:14 AM »
Dave Hull and I raced that bike in a four hour at phx int, in 1993. Pretty potent motor as I recall. Back then all 3 brakes were on the front master, with a chyrsler adjustable proportioning vavle for the rear.
I was never so sore, after riding that thins for a couple hours.
Glad you are restoring it.
David Blue
937-210-8721
Offline Turin
« Reply #55 on: October 16, 2016, 02:05:44 PM »
Dave, how cool is it that you raced this thing! I got it in pieces, and a lot is/was missing. I am putting back as much of the original pieces as possible (as raced). Tom Hull is adding a lot of his input into the build. He's going to build a 2-1 exhaust system.
1985 Sidlow Guzzi
« Reply #56 on: October 16, 2016, 04:37:57 PM »
Offline dblue
« Reply #57 on: October 16, 2016, 05:37:08 PM »
That SE was built by Lance Baker, who at the time worked for moto america, the importer, at that time.
the exhaust was a rennsprt 2-1-2, but dave made a2into 1 out of it. for ground clearance.
originally a battle of twins racer.
David Blue
937-210-8721
« Reply #58 on: October 16, 2016, 06:35:22 PM »
It's a small world, indeed, when you are fooling around with Guzzis.. :smiley: :boozing:
Offline Old Jock
« Reply #59 on: October 17, 2016, 05:49:46 AM »
Thanks for the info Turin
Still cannot get over how large they look on the wheel
I've got 6 pots ISRs on my Magni 1000 & they are awesome, I love being able to haul off speed with light 2 fingered action, reckon those will be the same
Looking forward to seeing it going together
