Author Topic: which one is exhaust valve?  (Read 6091 times)
Offline WHY
« on: April 06, 2016, 10:42:10 PM »
I am gonna do my 1st valve adjustment on a 2011 V7 racer. just double checking is the exhaust valve the one closer to the exhaust pipe (facing forward of the bike) on both cylinders?
2011 V7 Racer
Re: which one is exhaust valve?
« Reply #1 on: April 06, 2016, 10:49:50 PM »
 Yes . Ask questions , or do a search here , or both . Get it right the first time  :thumb:
« Reply #2 on: April 06, 2016, 10:49:56 PM »
Yes, in front.
« Reply #3 on: April 06, 2016, 11:19:45 PM »
 What RK said , just don't ask us about oil unless you have lots of spare time  :shocked: :laugh:
Offline WHY
« Reply #4 on: April 06, 2016, 11:43:04 PM »
Thanks guys, by the look of it its not too difficult. tried to change the air filter but fail to unplug the fuel quick connect so I gave up. worst part is unable to put the tank back on. the bolt was off by a few mm. end up trimming off some of the "puck" at the front to have a bit more room for the bolt to go back in. Yeah, lets not start another oil thread. been sticking with Agip 10w60 ever since. probably gonna switch to Motul 10W60 once I used up my Agip stock. over CAD 30$ difference for 4L.
2011 V7 Racer
« Reply #5 on: April 06, 2016, 11:49:20 PM »
 You wouldn't be the first one to have trouble with that "quick" disconnect . Someone give us some help here .
« Reply #6 on: April 07, 2016, 04:20:41 AM »
The valves should be very close, if it looks like they are more than one flat on the adjuster or a thou or 2 out get back.
Offline boatdetective
« Reply #7 on: April 07, 2016, 06:15:09 AM »
Good for you!  Remember, the best part of adjusting your valves is casually dropping this information with family and friends.
As mentioned- the easiest way to get messed up is to mistake the two times that the piston is at TDC. I would recommend taking the plugs out and spinning the wheel while staring enrapt at the valve actuation. After several turns, you will be chanting "Intake, Compression, Power, Exhaust". I use a section of 1/2" dowel to stick down the plug hole. It's stable enough to not wiggle around and jam. Very quickly, you will visually correlate the movement of the stick with the opening and closing of the respective valves.
On other smallblock matters, our member sign216 has done some very nice basic maintenance videos on his V7- you might want to look them up. Joe's a great guy.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
Online chuck peterson
« Reply #8 on: April 07, 2016, 06:44:12 AM »
And the 4 cycle motor goes....
Suck...
Push...
Bang....
Blow...
You'll want to adjust your valves at the point between push and bang
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #9 on: April 07, 2016, 07:09:31 AM »
Suck...
Squeeze...
Bang....
Blow...
FIXORED
« Reply #10 on: April 07, 2016, 07:30:17 AM »
I SAW that movie!
Offline sib
« Reply #11 on: April 07, 2016, 07:38:51 AM »
And don't believe the reply that says both exhaust valves are on the right side of the engine, and both intake valves are on the left.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #12 on: April 07, 2016, 08:33:15 AM »
  :coffee:  Computer screen
 I'm thinking that WHY may never come here again for advice . Wait , is this a two stroke ????
 Hey , one of you smart guys come up with an emoji that indicates coffee sprayed onto the pooter screen .
Offline drlapo
« Reply #13 on: April 07, 2016, 08:45:50 AM »
Only the seat requires removal to access the air filter
Offline twhitaker
« Reply #14 on: April 07, 2016, 09:29:58 AM »
I use a soda straw rather than a wooden dowel.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline Two Checks
« Reply #15 on: April 07, 2016, 04:17:59 PM »
Oil...that's a slippery subject.
1987 1000 SPII "Il Duce' II"
Offline Moto Fugazzi
    • Griso
« Reply #16 on: April 07, 2016, 08:10:51 PM »
The 2011 V7 should be the 2TB model, and the filter is under the tank. To remove the tank:
1. Unplug the connections going to the fuel pump assembly
2.Try to start the engine. Let it turn over a few times until the pressure is out of the fuel lines
3. Squeeze the round FI disconnect, and whilst squeezing, push it into the connector attached to the fuel pump. This should release it,           and then pull the round FI disconnect away from the pump connector. I also keep my other hand on the pump connector, as it's plastic and somewhat fragile.
Video here: https://www.youtube.com/watch?v=4SYAS5xsUlo
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
« Reply #17 on: April 07, 2016, 08:36:35 PM »
RE the fitting:
You can follow the instructions and it very well may work. However, I'd just offer the question: "how long are you prepared to fight, curse, and cry over a ten dollar fitting?"  There are replacement fittings at your local Autozone for only ten bucks that are way, way better than the shyte you have. I've had to replace them on two pikes and never regretted it. The only potential draw back is that you'll need a special set of pliers ($10-15) and "Oetiker" clamps to clamp on the new section of hose. Afterwards, of course, you'll still have the tool.
I know that you'll find plenty of folks here who have had no problems with the fitting. You'll find just as many who want to send a letter bomb to the person who spec'd this fitting.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
Online malik
« Reply #18 on: April 08, 2016, 07:40:56 AM »
I must be missing something. I can't see how removing the tank would give you access to the air filter on a 2TB 750. On the V7C, I remove the horn(s), the reg/rec & the plastic "splash guard" above it. That gives me access & room to wield the screwdriver for the 4 self tappers that fasten the door to the airbox where the filter lives. There's a bit of juggliing to get the cover out from between the frame rails, then a hand can go in & slide the filter out from its rails.
The last time I changed the filter a few days back was the easiest yet. But then there was only the airbox, the wiring loom & the front end left on the bike, so access was easy.
I've had the pleasure of removing the tank 3 times over the last few days (the V7C twice & the Breva once) and it seems to be getting easier, or I'm developing the knack. Took the time to examine the locking mechanism inside the QD coupler. It doesn't actually have to move very far at all, perhaps a millimeter or two. I had always been expecting a bigger movement & struggled to get it. It doesn't need much. A little silicone spray seemed to help loosen it. The Breva was more difficult to get the movement out of - don't think it had ever been off since leaving the factory - and it was stiffer.
