Author Topic: New clutch at the outer adjustment limits  (Read 3712 times)
Offline Allflatblack
« on: April 15, 2016, 10:59:08 AM »
I took out my G5 for its first run last week and it was great. The only issue was the clutch being pretty loose. It's a brand new clutch and I realize that the new disks make the rod fall far in and it will fall out as it wears. As of now, I'm at the maximum rod adjustment and the max cable adjustment. I have considered installing a longer bolt in the actuator arm. Any advice? Thanks!
Re: New clutch at the outer adjustment limits
« Reply #1 on: April 15, 2016, 11:33:32 AM »
A few questions:
1. what clutch plates are installed? SD-TEC?
2. How far recessed is the throw-out bearing outer body? This piece:
« Reply #2 on: April 15, 2016, 11:53:35 AM »
Thanks for the reply. I used the clutch kit from Stein-Dinse its been two years since I put the engine together but I believe http://www.stein-dinse.biz/Moto-Guzzi/Clutch/New-Version/Clutch-Kit-new-version-big-Model::790.html
I think that the outer bearing plunger is slightly recessed. I was concerned that I had missed a part but it has both washers and bearing attached, in good condition as in the parts drawings.
Online pehayes
« Reply #3 on: April 15, 2016, 12:05:24 PM »
That sounds about right, but we should explore what '...slightly...' means.  How about a picture?  Can you estimate the measurement of the recess?
« Reply #4 on: April 15, 2016, 12:20:57 PM »
Patrick,
I will take a measurement as soon as I get home, thanks!
« Reply #5 on: April 15, 2016, 12:39:14 PM »
but I will guess 3mm right now
« Reply #6 on: April 15, 2016, 12:45:58 PM »
Hmm, that's a fair amount..
« Reply #7 on: April 15, 2016, 01:00:57 PM »
Yep. I've run into this issue several times when using the SD-TEC plates. I either insert a steel ball between the clutch pushrod and throw-out inner body (down inside the inner body) or make a longer pushrod.
« Reply #8 on: April 15, 2016, 01:05:30 PM »
Ill take a look into what size ball I need, I have a bin of them from the CB race bike pushrod!
« Reply #9 on: April 15, 2016, 07:07:18 PM »
I give up trying to post a picture but the plunger is in more like 9mm. I'll look and see if one of my 8mm bearings will fit.
« Reply #10 on: April 15, 2016, 07:18:11 PM »
The ball goes in the other end of this piece, the inner body:
and the hole is 6 mm.
The ball does not go in between the outer and inner bodies, only the needle bearing goes there.
« Last Edit: April 15, 2016, 07:18:54 PM by Antietam Classic Cycle »
« Reply #11 on: April 15, 2016, 07:40:43 PM »
Yes, thank you-I assumed so. There used to be a hardware store down the street that sold this stuff but now it's gone. I imagine I'll spend the day driving around looking for a bearing and have to order from McMaster Carr anyway.
Thanks for your help. I'll report on my progress.
« Reply #12 on: April 15, 2016, 08:26:35 PM »
Buy a cheap ball bearing with the size of ball you need, crush/crack the outer race in a vise and harvest the balls. That's what I have done.
Offline chuck peterson
« Reply #13 on: April 16, 2016, 06:59:45 AM »
Love this forum...this kind of info is like gold
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #14 on: April 16, 2016, 12:38:22 PM »
Got the bearing in place. Clutch adjustments all nicely placed in the middle. Riding out to the Nortons meet at Washingtons Crossing State park tomorrow. Let's see what a few hundred miles feel like on this beast.
Thanks again.
