Author Topic: Heat help: Norge left shin burn  (Read 3855 times)
Offline steelby
« on: April 21, 2016, 06:39:59 PM »
I expect a reasonable amount of heat from the cylinders, but my left leg is really heating up about mid shin, front side.  It's burning.  After an aggressive ride yesterday, where there is a lot of gearshift action, It's really getting red and stings/burns/itches to the point it becomes distracting.
I've researched the archives, and there's a lot of "just deal with it" type advice.  There's got to be a way to get this heat off the left leg in the warm months.  There's already heat shields installed from the factory (2014 Norge) but they aren't getting the job done.
It's not bad on the brake side, as the leg position is farther back in the ready mode.  The gear side, however, requires a more forward, active position, which keeps the shin hot.
Yes, I move the toes down now and then and air it out, but when you're busy in a sport mode, you have to be right there working the gears.  High boots is an option but I don't want to wear horse riding boots.  I'm 6'2" so I am a bit close just by design, but there's got to be those of you out there that have found a solution.
I was even thinking of some kind of strap on leg shield for the left leg, that would just go over the pants, something I could easily remove.  Anybody come up with anything?
Offline old as dirt 2
Re: Heat help: Norge left shin burn
« Reply #1 on: April 21, 2016, 06:58:43 PM »
what are you wearing for gear? I wear tourmaster pants that have knee armor and have no issues
« Last Edit: April 21, 2016, 06:59:12 PM by old as dirt 2 »
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
Offline redrider90
« Reply #2 on: April 21, 2016, 07:18:21 PM »
Take a welders glove, cut off the palm section and then cut it in half. Use super glue to seal the where it is cut a d put velcro straps at one edge and a loop on the opposite side so the velcro hook and loop can interlock on the out side of the leg. Trouble is it may want to slide down.
Red 90 Mille GT
Offline ITSec
« Reply #3 on: April 21, 2016, 07:20:41 PM »
I live in Las Vegas, where it can be a bit warm much of the year. I have put over 100K on my Norge, so from time to time my legs have gotten a bit red - at least until I started doing what I probably should have all along.
For anything other than just commuting in the city, I use riding pants of some kind. The tightly woven material over the lower leg does a much better job than any khakis, jeans or other pants will in protecting you from heat. My go-to summer pants are Joe Rocket partial mesh pants, which have a solid panel over the lower front of the leg. I also use tall Sidi or Alpinestar riding boots on all but the hottest days - when I switch to Magnum tactical mesh (law enforcement) boots. The riding boots have shin protectors built-in, and the mesh boots cover enough that the pants do the rest.
Out here in the desert, all you can do is keep moving and stay hydrated!
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline cloudbase
« Reply #4 on: April 21, 2016, 08:28:41 PM »
I think MPH was working on a heat shield to take care of that.  Call and ask for Larry and he can fill you in.
Offline calfruit
« Reply #5 on: April 21, 2016, 08:56:29 PM »
I think something must be amiss here. I ride an 8v Norge in the Central Valley of Ca. I ride in an Aerostich  roadcrafter in winter and Olympia vented gear in summer and have never had an issue with heat.  This bike is cooler then my Honda ST1100 and my BMW K bike.
Offline bib
« Reply #6 on: April 21, 2016, 10:40:42 PM »
Ride a Norge 8v in NSW, OZ. In summer rode during a 41c day (105F), no problem with engine heat on legs  .. (I ride with 2 layers of denims - riding denims over work pants)
The heat I got was from melting tar on boots ...
Offline chuck peterson
« Reply #7 on: April 22, 2016, 04:22:27 AM »
Maybe you can adjust the shift lever enough to move your leg? Custom seat to move you back?
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Huzo
« Reply #8 on: April 22, 2016, 04:25:25 AM »
Yey Bibster, I'm an Aussie also and have done Ayers Rock etc on my Norge and thought it not too bad. Certainly a bit more of an issue than my mates R1100S, but jeez, nothing to worry about. Perhaps disconnect the spark plugs on the left side ????
« Reply #9 on: April 22, 2016, 06:10:00 AM »
I'd suspect something amiss also.  That side running too lean perhaps?
We've done several Norge seats-some for members of this forum-and moving the seat up and inch works a treat.  We could also move the "pocket" back a touch but this doesn't address the main issue.  My 14 runs the same temp on both sides and while I can feel a bit of het in summer it's nowhere near burn level.
Offline jim mac
  • TOO OLD TO DIE YOUNG www.guzzriders.org
« Reply #10 on: April 22, 2016, 06:59:02 AM »
Never had an issue with it.  i always wear long boots so i suppose that cuts down the rays.
Offline steelby
« Reply #11 on: April 22, 2016, 07:08:36 PM »
Just wear jeans.  Have riding pants but seem so bulky.  Good pair of Klim, but feel like a snowman in them.  Will check out some other styles/sizes see if I can't get this right...
They do keep heat off the leg, but everything else is bulked up...
Offline steelby
« Reply #12 on: April 22, 2016, 07:13:17 PM »
I'm going to try doubling up the denim.  Have not tried that...
Offline steelby
« Reply #13 on: April 22, 2016, 07:16:34 PM »
I will check into these products.  Sounds like the ticket...
Offline steelby
« Reply #14 on: April 22, 2016, 07:20:55 PM »
Thanks, I'll  call him.
Offline steelby
« Reply #15 on: April 22, 2016, 07:25:24 PM »
It's not that one side is hotter than the other, it's that the left leg rides a bit closer to the head, thus more heat.  Part of it is my riding position, not perfect, a little tall to get in a pocket crouch.
Offline bratman2
« Reply #16 on: April 22, 2016, 07:26:21 PM »
Wouldn't a computer tune take the heat down a notch. Made a noticeable difference on my 09.
Glenn Taylor
09 Norge with Staintune and Rexxer reflash
87 Subaru Brat (owned since 97)
« Reply #17 on: April 22, 2016, 07:53:22 PM »
It could be very dependent on your leg position.
When I put the 3/4 fairing on the T5 I noticed heat from the cyl for the first time.  I found that if I tucked my legs in close it went away.  1" out and they felt the heat.  Not horrible, but, it felt hot.  So, a small adjustment may work for you as well.  Maybe get those adjustable pegs and move them just a little.
Why left and not right?  If it is because of the cylinder stagger then it reinforces that a slight peg adjustment may fix it.  You could test the theory by riding with the left leg back just an inch or so.
But, I am just guessing.
