Author Topic: Breva 1100 Fuel Tank Cap Leak  (Read 3294 times)
Offline tris
« on: April 26, 2016, 01:24:56 AM »
When I parked the bike on its side the other day one of the things I noticed PDQ was the fuel pi$$ing out of the tank through the filler cap
I assume this is "not normal" but can't see anything that is obviously serviceable in there
Any guidance please as I don't fancy ending up sometime in the future with the bike on my leg and fuel pouring over me  :sad:
Cheers
PS Tank was about 3/4 full
1993 TW125 "POS" - Resting
Re: Breva 1100 Fuel Tank Cap Leak
« Reply #1 on: April 26, 2016, 07:12:44 AM »
2 lines coming out of tank, 1 is overflow vent, 1 is EVAP tank vent.
They crisscross by the rear tank mount, 1 goes down and is your cap area drain or overflow.
The other goes to a T and is your EVAP vent, goes to the can under rear seat by taillight.
You can access holes in cap area and clearly see the difference. Clean out w/air till it comes out at the fittings by rear tank mount. Then check hoses to can and drain, most likely one is burnt closed from exhaust.
If fuel has gone into charcoal can, delete it from sys cause it's now junk.
Offline tris
« Reply #2 on: April 26, 2016, 07:37:57 AM »
UK bike mate - no EVAP system  :grin: :grin:
Thanks though  :thumb:
Offline rdbandkab
« Reply #3 on: April 26, 2016, 09:41:38 AM »
 I suppose there's a vent tube and an overflow tube on the tank?    Make sure they're not pinched under the tank somewhere.
Make sure they're clear and that the one-way valve is working on the vent.
« Reply #4 on: April 26, 2016, 10:04:43 AM »
Same hose fittings on all, same tank. Use air to find blockage. Easy task.
Offline tris
« Reply #5 on: April 26, 2016, 10:06:32 AM »
OK TA - I'll check that out
Offline Nick
« Reply #6 on: April 26, 2016, 10:32:08 AM »
Had it happen on my Tuono. Check this post out, and the links in it also. I think your gas cap is the same as this one.
http://www.apriliaforum.com/forums/showthread.php?288661-RE-2007-tuono-gas-cap-leaking-under-acceleration&highlight=gas+cap+leak
Offline tris
« Reply #7 on: April 26, 2016, 02:10:30 PM »
And the prize goes to.....Nick
Spot on call mate -thanks
Just need to blag the right sized O-ring from work tomorrow
Cheers
Tris
Offline tris
« Reply #8 on: April 27, 2016, 02:08:38 AM »
DOH - what's the point of going to work if you can't liberate the right stuff to fix your motorcycle  :rolleyes:
Only got 1/8" O-rings when I need 1/16" here
