Author Topic: WTB - Leading link or other sidecar-type front end -- but which one?  (Read 9975 times)
I'm investigating different options for improving the steering on the trike.  I've raised the forks about as far as they'll go (had to add spacers to the handlebar risers to clear the fork tube ends), and I'm still rassling it through high speed twisties.  I understand these earle's fork and other leading link sidehack front ends help with the steering effort.  Also, traditional trees with modified offsets seem to be out there.  I'm ignorant abut the comparative advantages and suitability of the different designs.  All I know is that I'd like a range of adjustability to it.  Anyone want to help me understand the fancy front ends?  Anyone have a setup suitable for a new-type tonti steering neck for sale?
Offline dsrdave
Re: WTB - Leading link or other sidecar-type front end -- but which one?
« Reply #1 on: April 27, 2016, 07:28:54 PM »
I ordered a Ural leading link off eBay for $450 incl freight out of russia.  I'm pretty sure I can adapt it to my  'vert  hack.  The modified triple tree helps a bit but not worth the investment in my opinion.
« Reply #2 on: April 27, 2016, 07:42:45 PM »
modified triple clamps were done by the Steerite company (in Canada?) I think they went out of business..
Offline radguzzi
« Reply #3 on: April 27, 2016, 07:58:12 PM »
I bought a Unit Leading Link Fork several years ago, got it from a fellow that took the assembly off his Stone so the cost was exactly half of new.  Fits right into the stock EV trees...
Works for me.
Picking up the Christmas tree with the Grandsons...
A Saturday rip to the lumer yard...
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline Rich A
« Reply #4 on: April 27, 2016, 08:19:42 PM »
I had a set modified by them--they work very well.
Rich
Offline fatbob
« Reply #5 on: April 27, 2016, 08:46:31 PM »
I have the Unit fork on my R100 / Watsonian rig. It is like having power steering
Bob Lower
'07 Norge
'01 K1200LT
'10 Thunderbird
'88 FLHS
'79 R100T
'03 R1150RT
'07 GTS 250
« Reply #6 on: April 27, 2016, 11:41:15 PM »
  Use one with a steering damper.
« Reply #7 on: April 28, 2016, 06:17:15 AM »
I had the first Unit fork to be put on a Jackal on the Jack-All hack tractor.
Yep.
That sounds like it would be right down your alley..
« Reply #8 on: April 28, 2016, 09:15:29 AM »
 A couple of questions and an observation or two . Has anyone ever tried an Earles fork on a trike ? My understanding is the main two advantages of the Earles are greatly reduced trail and the fact that a leading link fork tends to rise under braking . Just curious , the dynamics of a trike and a sidecar rig would seem to be different , the trike concentrates more weight over the rear , while a hack distributes weight more evenly , correct ? Not sure if this is even possible in this application , but an investigation into the way HD sets up their forks and triple trees on the FLH series might be worthwhile . Just food for thought , I'll be quiet now .
redrider
« Reply #9 on: April 28, 2016, 10:50:16 AM »
There are tremendous side forces on the front end. Leading link/ Earles provides necessary rigidity.
Offline Shorty
« Reply #10 on: April 28, 2016, 11:24:04 AM »
Buy the one from the previous post about the sidecar/Cal II for sale. For <the price of a new front end, you also get Guzzi spares.....As handy as you are, if the stock setting don't suit you, you could make a bottom swingarm with the adjustments you need.      http://wildguzzi.com/forum/index.php?topic=83115.0
« Reply #11 on: April 28, 2016, 12:19:44 PM »
All constructive comments are welcome, Dusty.
I thought about the Cal II hack, but the paperwork stops me.  I'd have to find some way of parting it out on-the-spot.
So far it appears the Unit unit is favored.  I see that Dauntless (DMC) in WA has some custom front ends and trees for their hack and trike conversions.  Has anyone used their products?
Offline jackson
« Reply #12 on: April 28, 2016, 01:10:35 PM »
I have never bought anything from Dauntless but my wife and I owned seven sidecar rigs over a period of 30 years and five of our rigs had leading link front ends; they were GREAT.  But, I've never seen a leading link fitted to a trike BUT have seen modified triple trees on a lot of them.  Around ten years ago, Dauntless was loved by some and despised by others due to mounts that they had purchased, not fitting correctly, etc.  From what I've read, Dauntless cleaned up their act and I haven't heard or read anything negative about them in years.  They've been around long enough and have sold enough sidecars, frames, rigs, front ends, etc. so they're probably your best best for reliable information re. whether to use a modified triple tree or a leading link on a trike.
NO longer can ride
« Reply #13 on: April 28, 2016, 04:14:51 PM »
Good informaion, Jackson, thanks!
I visited DMC a few years back after the WA breakfast.  I thought the people were nice, and it looked like a busy shop.  I am considering another visit this summer for some tech advise.
« Reply #14 on: April 28, 2016, 06:57:46 PM »
I can find ural leading link parts here and there -- I see a pair of forks in Canada.  Can you tell me what the fork tube diameter is on those, and does it look like you can get a pair of calipers mounted to them?
Offline dsrdave
« Reply #15 on: April 28, 2016, 07:53:54 PM »
I have not recieved the fork assy yet.  Rough dimensions taken from a Ural were enough to convince me it could be done.  The one I bought included the triple tree assy.  Ural uses Brembo calipers.  The seller was good enough to remove the drum brake set up and replace with the single disc brake setup.  I will add an add'l. Caliper as I believe it to be needed.  My plan was to use the guzzi wheel, disc, and calipers adapted to the Ural fork.  And probably use the Ural triple tree and Bush to fit the guzzi yoke.  I'm away from the shop for a while.  I'll be back in mid May and will start on the adaptation then.  I'll have a LOT more answers for you by mid june...... hope this helps, dave.
Offline dsrdave
« Reply #16 on: April 28, 2016, 08:04:07 PM »
RK, if you use the key words: leading link fork ural.  You should find it on ebay.  The seller is iural75
« Reply #17 on: April 28, 2016, 08:07:49 PM »
There's a ural in town with the brembo brakes on the front end, but I haven't seen him this year yet.  When I do I'll make him come by for a fitting.
But please humor my dimension questions when you get back.  I'll have my rig in America in June and hope to splice on whatever I end up with on-the-spot.  So it would be handy to know if the ural upper tubes would slip into my trees or if I'll have a nightmare of adaptions to make.
I found the ural postings on ebay.  I sent him an email.  All I see is the disk brake version in his inventory.  Looking at the parts lists I'm not sure how it becomes adapted to disks.
Offline dsrdave
« Reply #18 on: April 28, 2016, 08:28:50 PM »
I'll be happy to get you the dimensions.  Feel free to pester me if I forget.  I know the tube diameter is very close, the problem is with the spacing.
« Reply #19 on: April 28, 2016, 08:34:02 PM »
But your 'vert has umm . . . 35mm forks @110mm (iirc from a recent topic here), and I believe the EV has 43 or 45mm forks with wider spacing.
Offline Porterhouse
  • GRiSO / Stelvio - A One and-a Two
  • GRiSO, he speaks to you, no?
    • the GRiSO ghetto
« Reply #20 on: April 28, 2016, 11:44:18 PM »
Dauntless (DMC) has severed ties with the machinist who was making the offset triple trees for Guzzis.  Ownership has made no effort to source elsewhere...
Looking to DMC is a dead end.
GRiSOghetto - all GRiSO, all the time...  |  Life ain't easy for a boy named Sue - RIP my best friend...
Online jrt
« Reply #21 on: April 29, 2016, 07:50:31 AM »
Unit Forks are expensive and worth it.
Sidestrider (Doug Bingham) in Los Angeles was a dealer for Unit.  Don't know if he still is- or even if he is still in business.
sidestrider.com
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Online John A
« Reply #22 on: April 29, 2016, 08:02:15 AM »
Bob Nolan built some leading link forks, but I was not interested in them back then. Now I am contemplating doing it, sure miss Bob. Does any body have engineering drawings? That would solve the hard part.
« Reply #23 on: April 29, 2016, 02:29:51 PM »
Bob was a one-of-a-kind.  I didn't know he made leading links though -- or maybe, like you, I just don't remember because I had no interest at the time.  I can find out if there are any left -- I still have a line on Marian.  I'll send an email.
I found drawings doing google searches.  Unfortunately, the text for the callouts wasn't in the collections, so while I have pictures, there's no 'splainin.
« Reply #24 on: April 30, 2016, 01:22:17 AM »
sidestrider.com
Doug Bingham died a few months ago. RIP   :lipsrsealed:
Offline rudyr
« Reply #25 on: April 30, 2016, 11:51:59 PM »
I had the guy in Canada fix a tree a few years ago, so I call his stopped as you know.  But he told me to check with Custom tripletree.com.  He want my tree(Jackal 2000) as a tinplet.  And $1000 plus.  Wasp in leading link in England want with import duty and the shocks (got to shipped by them selfs) $2400 US.  The guy Au. Wants $3500 plus freight and duties.So the Ural sounds good.Rudyr
Offline rudyr
« Reply #26 on: May 01, 2016, 08:26:41 PM »
Didn't have all facts last nite.  SteerRite son told me to check with the people in Il.  The wasp leading link sent a hand drawn picture what measurement on a Triumph bonneville(didn't know what they would be a Triumph ,England ah.) The guy from Au(down under) he got right back to and didn't need anything but money, to send it right up.  A friend of mine has a Ural going take a few measurement and look on EBay.Rudy
« Reply #27 on: May 02, 2016, 01:15:57 AM »
I appreciate your effort, rudyr.   :smiley:  For measuring purposes, mine is also a Jackal.  If a ural can be made to fit yours, it will work on mine.
I've got some feelers out for possible used ones, and I'm calling around the trike/sidecar shops (they're mostly not open over the weekends) to see what they might advise.  The drum brake set on ebay was coming out of Russia and was wrecked/rebuilt.  It seemed like more of a risk than I wanted to take.  Also, the seller did not tell me what the fork tube diameter or spacing is, and he has sold it.  So I don't have any measurements.
I'm kinda surprised that none of the sidecar guys on WG have an extra one in their stash.  I've got an ad in the classified too, and there has been no comment on it at all.  I'll drive to where it is, assuming the seller will let me swap it out on-the-spot.
Offline rudyr
« Reply #28 on: May 02, 2016, 06:46:05 AM »
You know I have run a raked tree for years and I have no issue with them, except head shake( must keep one hand on bars all the time).   I told the guy in Il. I could get a tree for a Harly for $650 and he's got them for that.  But hadn't made one for a Guzzi or Triumph.  I've got two Jackal's and have the tree pulled off one now.  Just haven't sent it yet $1000 plus just upsets me.Rudyr
« Last Edit: May 02, 2016, 08:38:40 AM by oldbike54 »
Offline dsrdave
« Reply #29 on: May 02, 2016, 09:00:58 AM »
The Ural guy on eBay was good enough to swap the drum brake for a dust brake set up for me.  I just need to replicate it for the second disc.
