Author Topic: 95 Sport  (Read 3627 times)
Offline motoscotto
95 Sport
« on: April 29, 2016, 09:53:00 AM »
Hi everyone, I haven't been active for some time but spring is here and I have a project, I have a 1995 Sport with 10K on it, the tranny is leaking gear oil all over my rear tire, I believe is is the shifter seal in the rear cover, I am going to pull the tranny and want to go through it, I have no experience in gear boxes so my question, is there anyone that can go through my tranny to replace all the seals and orings, replace bearings, and shim shift drum if needed. I am willing to ship. I live in Northern Wisconsin. any advice or help will be appreciated thanks
1996 1100 Sport RED
1987 Blue&Cream Heritage Softail
1983 Honda CB 1000
12013 Artic Cat Red 500 ATV
1980 Suzuki GS 550 (1)
1974 Honda CL 360
1977 Honda CJ 360 T
Re: 95 Sport
« Reply #1 on: April 29, 2016, 10:42:59 AM »
Well, Jim at Rose Farm could do it of course. My Kid could do it but probably doesn't want the job. Even I could do it, but I don't want the job, either.  :smiley: If you're mechanically inclined, I'll bet you could do it. Just look up the tutorials on This old tractor. It's not rocket science.
Re: 95 Sport
« Reply #2 on: April 29, 2016, 10:57:47 AM »
I wonder how much shipping to Australia would be?  Pete Roper is the man!
But yeah, I think Jim at Rose Farm would be your closest best bet.
Online Tkelly
Re: 95 Sport
« Reply #3 on: April 29, 2016, 01:50:44 PM »
There is a shop in NW WI.
Offline Vince in Milwaukee
Re: 95 Sport
« Reply #4 on: April 29, 2016, 02:22:53 PM »
I would give The Guzzi Doctor a call (he advertises on here and is a board sponser).  His shop is in North Chicago, Illinois.  He's done the xmission on my LM3 and also a top end job - I couldn't be more pleased.  My bike is down in his shop as I type - time for new brake lines and a new head light assembly.
Gone but not forgotten:
Re: 95 Sport
« Reply #5 on: April 29, 2016, 05:10:41 PM »
While its apart throw in a pair of 3205-AC3 bearings instead of the ATN9's. Also be aware that the straight cut boxes on the 95 Sports are prone to trashing themselves due to a combination of poor case hardening, the lack of a Cush drive in the rear wheel and an unforgiving face cam spring in the box. The three dog engagement also means that if they are ridden in a lumpen, softcock manner they will degrade quicker than if they are grabbed by the horns and given a good thrashing!
Re: 95 Sport
« Reply #6 on: April 29, 2016, 05:46:58 PM »
Uhhh, wat Pete says.  :smiley: The Kid's transmission was pretty much toast from a (ahem) softcock rider and the 3 dog deal. He (we) swapped in modern internal parts and the new bearings. Pretty easy, but you *do* lose the kool straight cut gears.
Offline groundhog105
Re: 95 Sport
« Reply #7 on: April 29, 2016, 11:17:06 PM »
Sean Fader at RTL Moto does a lot of transmissions on the west coast.  Did my Lemans 5. Honest guy and excellent work.
Re: 95 Sport
« Reply #8 on: April 30, 2016, 07:18:32 PM »
Good to know for West options.  Thanks.
« Last Edit: May 01, 2016, 10:07:32 PM by Tom »
Re: 95 Sport
« Reply #9 on: May 01, 2016, 06:00:13 AM »
I doubt if you'll find a better mechanic than Sean, Tom.. old stuff, new stuff, big block, small block.
redrider
Re: 95 Sport
« Reply #10 on: May 01, 2016, 07:52:01 AM »
I live in SC and can/will do it for you. I have already been through the Mille GT box-no parts, just a shim job. It really made a difference in shift quality. My own Sport has a new clutch but needs the bearing upgrade for peace of mind. It should take two weeks to strip, order parts and reassemble.
Offline motoscotto
Re: 95 Sport
« Reply #11 on: May 01, 2016, 03:56:32 PM »
I sent you a PM
1996 1100 Sport RED
1983 Honda CB 1000
1974 Honda CL 360
1977 Honda CJ 360 T
Offline motoscotto
Re: 95 Sport
« Reply #12 on: May 02, 2016, 11:10:29 AM »
Can you PM me with a quote, thanks
1996 1100 Sport RED
1983 Honda CB 1000
1974 Honda CL 360
1977 Honda CJ 360 T
Offline motoscotto
Re: 95 Sport
« Reply #13 on: May 08, 2016, 08:12:15 PM »
Well I pulled the tranny today and prepped it for shipping, looks like Joe {RedRider} is going to go through it and do the things we talked about. I still have to tear down the clutch , with 10,000 miles on it I hope its ok, then I will replace the rear seal in the motor, last I am rebuilding the carbs, the rubber intake boots are extremely weather checked so they will be replaced. Overall I will check out things clean them up and put it back together. Any Tricks and Tips  will be considered.
1996 1100 Sport RED
1983 Honda CB 1000
1974 Honda CL 360
1977 Honda CJ 360 T
