Author Topic: I bought a battery backup..........  (Read 11732 times)
Re: I bought a battery backup..........
« Reply #30 on: May 02, 2016, 08:43:00 AM »
FWIW, almost all the batteries are made in the same factories overseas.  The differences are in the charging electronics, and these days even those are part of the battery mfg process.
Check yours fairly often, especially the LiIon or LiPo types.  The newer chemistries tend to cause swelling of the packs when left fully charged over a period of time.  They do not burst, just swell a bit.  The LiFe packs are a bit more forgiving that way, and they do not burn as readily as the other chemistries.
« Reply #31 on: May 02, 2016, 12:47:54 PM »
That seems contradictory since you want them charged in case you need them.  :huh:
« Reply #32 on: May 02, 2016, 12:49:16 PM »
Here's a novel thought.  Read and follow the instruction manual that comes with the battery pack, no matter who makes them.
« Reply #33 on: May 02, 2016, 01:01:15 PM »
Lithium type batteries tend to deteriorate faster at 100% charge. They are quickly destroyed if under-charged or over-charged.
Most companies recommend closer to a 50% charge for long term storage.
Basically, charge it the way you need it to be used, don't expect it to be any good in 5 years.
Oh, and the hot car trunk is the worse place to keep it. What to do, what to do.
« Last Edit: May 02, 2016, 01:33:28 PM by OMG »
« Reply #34 on: May 04, 2016, 01:36:17 PM »
With the help of much more knowledgeable users here I ended up returning my 12A overpriced Stanley unit and ordered a $34 200A smaller Walmart unit (snap suspenders).   :grin:
Offline kevdog3019
« Reply #35 on: May 04, 2016, 04:32:00 PM »
I hope you don't want to jump any cars with that!  It will probably jump a sb Guzzi with time but that's about it.  Good for a phone re-charge.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
« Reply #36 on: May 04, 2016, 05:02:00 PM »
I have a separate 1 for jumping car/truck.
« Reply #37 on: May 04, 2016, 07:48:53 PM »
It just used my $31 one on my daughters car.
Good investment IMHO.
« Last Edit: May 04, 2016, 07:49:43 PM by OMG »
« Reply #38 on: May 04, 2016, 10:38:10 PM »
There might be some misunderstanding about capacities.
The batteries will have a max cranking current, such as 200A or 400A.
They also have a capacity, which will be something like 12Ahr or 12,000mAhr.  For reference, your phone is probably around 2000mAhr (but it is also only 3.7V).
A 12Ahr battery can still put out 200A, but can only do that for a couple minutes.
« Reply #39 on: May 04, 2016, 11:12:03 PM »
Peak output of 400A = 200A actual output in reality.  That's what I go by.
« Reply #40 on: May 05, 2016, 08:46:12 AM »
I got one @ Sam's for $19.95 last night<shrug>
« Reply #41 on: May 08, 2016, 07:14:33 PM »
Is it a Schumacher 300CCA like I saw @ Walmart today?
