Author Topic: Self Adjusting ECU  (Read 4724 times)
Offline Jerryd
Self Adjusting ECU
« on: May 02, 2016, 09:23:04 AM »
Maybe the Subject Line could be different, but my question is whether the ECU in a Norge will compensate to a minor change in the silencer. For instance, will taking the DB Killer out of my Mistral cause an issue without a reflash? Seems like I have read that somewhere (maybe an Urban Tale) that if you disconnect the battery for a while, before you remove the silencer, reconnect and start up the bike, it will compensate for the change.
Sorry if this is a dumb question!
Jerry
Florida
Offline old as dirt 2
Re: Self Adjusting ECU
« Reply #1 on: May 02, 2016, 10:08:38 AM »
I just installed my mistral and didn't do a thing. runs great. did you replace the cat box with a new crossover pipe as well?
I elected to remove the db killer for better sound.
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
beetle
« Reply #2 on: May 02, 2016, 03:45:54 PM »
Unless you are running an open-loop map, the ECU will trim the fuel when the exhaust is changed in a way that the AFR may be affected. The trims (or auto learning parameters) are volatile. That is, you can reset them with software like GuzziDiag, or by pulling the main fuses if disconnecting the battery for 60 seconds. The ECU then runs the base map, but starts to trim again. You should reset them after a change. It speeds up the process.
« Last Edit: May 02, 2016, 03:46:28 PM by beetle »
Offline Jerryd
« Reply #3 on: May 02, 2016, 04:35:55 PM »
So, if I understand correctly. After removing the dB killer from the Mistral, just disconnect the battery for a couple of minutes, reconnect, and it will re-trim? Will it auto learn without powering down?
Jerry
Florida
« Reply #4 on: May 02, 2016, 04:46:53 PM »
If you don't disconnect the battery or pull the main fuse it will re trim but it will take a lot longer.
« Reply #5 on: May 02, 2016, 05:17:19 PM »
Why take out the DB killer?  Even with it, it's gotta sound better than stock.
Offline Jerryd
« Reply #6 on: May 02, 2016, 06:27:08 PM »
Thanks Pete!
Jerry
Florida
Offline atavar
« Reply #7 on: May 02, 2016, 06:34:22 PM »
Pete, you will know better than I, but do you need to touch the disconnected cables (NOT THE BATTERY TERMINALS) together to discharge the ECU capacitors so it loses it's memory?  IIRC if you don't have to reset the clock the ECU did not reset.
« Reply #8 on: May 02, 2016, 07:28:08 PM »
No.
