Author Topic: NGC - The Indian runs!  (Read 8934 times)
Re: NGC - The Indian runs!
« Reply #30 on: September 02, 2016, 03:08:26 PM »
Suicide clutch needs the foot to depress the pedal to keep clutch out like a car.  Normally there is no heel rest.  I use the floorboard.  When I built my Recon (reconstructed motorcycle), I originally ran the bike with a belt drive and suicide clutch.  Not too much modulation on the pedal.  Because  of the hole shots I was doing, I wanted to put on a rock & roll pedal on it.  The rock & roll clutch pedal has a heel rest and you could lock the clutch out.
This is helpful coming down to a stop.  You can lock the clutch out then shift into neutral.  I originally had a rock & roll pedal on.  I wanted the option of electric start.  I traded the the belt drive and put on stock cases with the starter motor and primary chain.  I could only use the suicide clutch pedal but I could put floorboards on.  The side cases and the floorboards make the bike wider.  Great for leaving sparks when doing tight turns.  When coming to a stop you have to shift into neutral before coming to a complete stop.  You'll fall over if you don't or kill the engine.  Not fun with traffic behind you and the electric start doesn't work.  Kick-start only.
At this point, you have to go thru the starting drill for a hot engine.  :tongue:
« Reply #31 on: September 02, 2016, 03:12:42 PM »
 Oh heck , Beetle is going to call me pedantic , but I think you mean the clutch ENgages by rocking it back , as in it "takes up" . Sorry , I will go back to my corner  :embarrassed:
« Reply #32 on: September 02, 2016, 04:50:45 PM »
Yeah, whatever.....I didn't put it on.
