Author Topic: Breva 1100 pinch bolts  (Read 2100 times)
Offline tris
« on: May 07, 2016, 02:54:42 PM »
What are the torque settings for the front axle pinch bolts?
I've found the axle torque (80Nm) but despite searching high and low I can't find the torque for the pinch bolts at the bottom of the legs
Can anyone help?
Cheers
1993 TW125 "POS" - Resting
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: Breva 1100 pinch bolts
« Reply #1 on: May 07, 2016, 03:04:39 PM »
For small screws & bolts, I prefer to use a short spanner (wrench) rather than a torque wrench.  I believe I can "feel" the right amount, I'm never impressed with what the torque wrench offers.
YMMV.
Offline Kai
« Reply #2 on: May 07, 2016, 03:06:08 PM »
10 Nm for the M6 pinch bolts
Spending my free time mostly with these Guzzis
« Reply #3 on: May 07, 2016, 05:06:53 PM »
YMMV.
Yeah, me too. Torque wrenches are for amateurs, head, flywheel, and con rod bolts.  :evil: Oh yeah.. propeller bolts.  :smiley:
Offline tris
« Reply #4 on: May 08, 2016, 02:29:02 AM »
I usually do small fasteners by feel too but having read about the dangers of cracking the end of the fork leg if the clamp bolts are over tightened was a bit concerned!!!!
Feel for about 1Nm it is
Cheers
« Reply #5 on: May 08, 2016, 02:30:06 AM »
Don't know if it's the same as the Norge, but on mine I use a T handle Allen wrench, but also make sure you have the torque the same on both bolts, 'cos as you nip one up, the other will need a touch again. Just use "feel" and approach the desired torque in gentle increments.
