Author Topic: Norge 8V - 1st gear notchy  (Read 4209 times)
Offline Cool Runnings
« on: May 08, 2016, 12:55:49 PM »
Do I need a custom exhaust with beetle's map in order to correct 1st gear horrors?
Offline sbaker
  • Piaggio Stock Holder
Re: Norge 8V - 1st gear notchy
« Reply #1 on: May 08, 2016, 04:40:05 PM »
NO.. you need properly tuned bike, with the correct factory map. "Adjust" the EPA canister minimize its effects AND make sure the throttle cables have the proper tension. Balance the TB's and it will be fine!
Sam
Dallas, TX
AGATT
Current
Norge Wing: White Squadron
Ducati 900ss
Previous
1975 Convert + Sidecar - Fun
2004 California EV Touring
« Reply #2 on: May 08, 2016, 04:53:56 PM »
So, sounds like I need to get after my dealer as it's under warranty through 2017 (about 1,400 miles now).
« Reply #3 on: May 09, 2016, 07:58:12 AM »
So, the stock FI mapping on the Norge should not be notchy?
Offline JeffOlson
« Reply #4 on: May 09, 2016, 08:23:39 AM »
When you say "notchy," do you mean that your Norge bucks and lurches at low throttle settings in first gear? If so, then Beetle's map largely cured my current Norge of that. I believe the bucking and lurching is due to the stock map being overly lean. (My Ducati was far worse!) Also, my previous Norge had an Agostini can with the DB killer removed. The ECU trimmed around the more open silencer, causing the engine to run richer, largely eliminating the bucking and lurching (and making the Norge sound glorious in the process!).
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #5 on: May 09, 2016, 08:25:56 AM »
Maybe just a loose throttle cable.
« Reply #6 on: May 09, 2016, 08:27:02 AM »
Thanks Jeff, Beetle's map along with a new can are in the works. I want to hear some grunt. Besides, loud pipes DO SAVE LIVES.  :thumb:
Offline JeffOlson
« Reply #7 on: May 09, 2016, 08:27:56 AM »
There's the spirit!
2018 Vespa GTS 300
2015 Vespa GTS 300
« Reply #8 on: May 09, 2016, 08:29:36 AM »
I was thinking a overly tight throttle cable. The smallest movement of the throttle and it lurches forward, backing off and it bucks. Not a lot of fun in stop and go traffic.
Offline JeffOlson
« Reply #9 on: May 09, 2016, 08:35:21 AM »
I have not tried a Throttle Tamer, but on e of those might help, too (if they make one that will fit the Norge):
http://www.g2ergo.com/wp-content/uploads/tamer.jpg
« Last Edit: May 09, 2016, 08:35:46 AM by JeffOlson »
2018 Vespa GTS 300
2015 Vespa GTS 300
« Reply #10 on: May 09, 2016, 08:38:51 AM »
Jeff, was thinking about that solution yesterday, may look into installing one?
Offline JeffOlson
« Reply #11 on: May 09, 2016, 08:43:38 AM »
If they make one that fits, I may give it a try, too. Beetle's map has been very helpful at eliminating low-speed bucking and lurching, but not entirely.
2018 Vespa GTS 300
2015 Vespa GTS 300
« Reply #12 on: May 09, 2016, 09:10:05 AM »
Who did the last throttle body sync and TPS reset. Maybe it just need cleaned up a bit.
Offline JeffOlson
« Reply #13 on: May 09, 2016, 09:32:56 AM »
On my first Norge, Moto Guzzi Portland. On my second Norge, Moto International. For both PDIs and first services. However, the snatchiness/bucking/lurching has always been there to some degree, at low speeds, in first gear.
2018 Vespa GTS 300
2015 Vespa GTS 300
