Author Topic: 1998 V11EV WIRES  (Read 2322 times)
Offline n3303j
  • Ron Cichowski
1998 V11EV WIRES
« on: May 11, 2016, 08:27:30 PM »
So I've had this critter a few weeks now. I've done more wrenching than riding so far. Bike looked well cared for but had NO SERVICE HISTORY. So at 41,000 miles I'm inspecting and servicing EVERYTHING. Full shop manual and parts book in high quality color is available online. Ran off a fancy copy where I used to work. It's a really great way to get intimate with a new machine.
So here I am changing brake fluid at the rear master cylinder and looking over the plug that goes into the ECU. There are a couple of connectors pigtailed out the back of this connector. One is #56, a three wire "diagnostic" plug.
THE ONE IN QUESTION:
Plug #26 is a two wire round polarized connector. It mated with a second connector that at one time had something on the wire ends.
This is labeled "LIGHT EMITTING DIODE (CHECK LAMP)" on the proper wiring diagram.
Couldn't find any info what this lamp might be for. Got the feeling it might be left unplugged unless doing diagnostics? I remember reading flash codes out of a car diagnostic port using an LED before modern diagnostics were commonplace.
ANYONE? What is this lamp for?
« Last Edit: May 11, 2016, 08:31:14 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline BMCMOTO
Re: 1998 V11EV WIRES
« Reply #1 on: May 11, 2016, 08:29:28 PM »
Hammer, meet nail!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #2 on: May 11, 2016, 08:42:31 PM »
 We had this discussion some time back , seems someone concluded it is either a European diagnostic thingie that never gets employed , or Luigi was just screwing with us  :shocked:
« Last Edit: May 11, 2016, 08:43:28 PM by oldbike54 »
« Reply #3 on: May 11, 2016, 08:50:41 PM »
exactly.. the 98 EV can spit out fault codes.. It's all detailed in the FI supplement manual.
Offline n3303j
  • Ron Cichowski
« Reply #4 on: May 12, 2016, 12:41:38 AM »
Copy of the FI manual anywhere on line?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline pehayes
« Reply #5 on: May 12, 2016, 01:32:54 AM »
Did you find the little red LED lamp nearby in the seat latch bracket?  As I recall, there should be a little cap dangling nearby the plug.  You install the cap and then turn the key to on.  If there are faults the LED will flash numbers.  The system is crude and rudimentary.  It does not 'store' faults.  The fault has to be currently active such as a failed sensor.
Offline JoeB
« Reply #6 on: May 12, 2016, 05:29:01 AM »
http://dpguzzi.com/efiman.pdf
If you happen to need better relay's at a decent price this is the place to find them.
http://dpguzzi.com
« Reply #7 on: May 12, 2016, 07:06:20 AM »
<shrug> Standard operating procedure for me. That little code blinker *might* be better than nothing, but not by much. Getcha some cables, getcha Guzzidaig. You could have been burnt for a witch if you had that stuff in 98..
