Author Topic: Crappy batteries  (Read 11215 times)
Offline Two Checks
Re: Crappy batteries
« Reply #30 on: May 14, 2016, 05:34:16 PM »
Sonneschein has been an Exide company since 1996.
1987 1000 SPII "Il Duce' II"
« Reply #31 on: May 14, 2016, 05:37:23 PM »
I understand the owner doing bonehead things with the electrics.  I don't understand when the factory designs in a weakness like that.  It's just too easy to figure out an aux power source for the techno-trinkets.
Not quite sure what causes it but the Baby B. has a parasitic drain that will flatten the battery in a month.
I tend to actually use this to keep the battery fresh; every 3 weeks when the bike is not being used I will put on my 3amp smart charger and remove it when it reaches 'float". As I understand it, this actually lessens the chances of sulphonation. I got 7 years out of the first Guzzi branded Yuasa wet cell, and 5 years and counting out of this one.
Works for me. <shrug>
« Reply #32 on: May 14, 2016, 05:39:12 PM »
 Having had two RT beemers with the clock in question , no , they aren't causing the problem .
Offline gnorts
  • Fate l'amore, non la guerra
« Reply #33 on: May 14, 2016, 05:41:19 PM »
Ah.  I dinna know that.  My problems with their product were in '94 and '95.
My condolences to Sonnenschein.
'15 Griso 1200SE "il razzo rosso"
redrider
« Reply #34 on: May 14, 2016, 06:11:34 PM »
Many years ago I worked for a battery service company-forklift and such. Exide closed the local factory and moved to Mehico. Quality went south as well. And do NOT get me started on the beer distilleries down there.
« Reply #35 on: May 14, 2016, 06:46:59 PM »
Are you saying that the beer tastes like battery acid? :shocked: :shocked: :wink:
OldBMWMaster
« Reply #36 on: May 15, 2016, 05:30:34 AM »
My BMW R1100RT  ate two batteries before I figured out the problem was my GPS.  Its battery was bad and it was acting a a huge drain on the battery.  Hope this helps,
Offline drlapo
« Reply #37 on: May 15, 2016, 08:20:41 AM »
I still suspect a batch of bad batteries. All three came from the same manufacturer and may be from the same lot.
The clock drain never killed the Wal-Mart battery and it gets a boost via a tender if it sits more than a week.
I ordered an AGM battery
« Reply #38 on: May 15, 2016, 05:08:04 PM »
Why not? Anheuser-Busch created an entire empire out of the stuff... :rolleyes:
Offline krglorioso
« Reply #39 on: May 15, 2016, 10:05:16 PM »
I use a Battery Tender on 4 of my 5 vehicles; the ones that do not get regular use.  As stephenm correctly notes, above, a Battery Tender monitors a battery's state of charge and only adds charge if battery falls below a certain voltage.  My Odyssey battery was a few years old in 2011, when I got the 03 Stone Touring it was in, and it still is working fine.  I load test it every six months, just to be sure.
Ralph
Ralph
2004 Moto Guzzi Breva 750
2017 Honda CB-500F
Offline steven c
« Reply #40 on: May 16, 2016, 08:45:37 AM »
"I've been using the $7 Harbor Freight trickle charger, which feeds 14.2 volts at .5 amp. It's not really a float charger and if you leave it connected for days at a time it can cook a battery. Best to hook it up for a few hours each month, or put it on a timer that gooses the battery for a few minutes a day. "
 Be careful eith the HB chargers, my nephew had one melt down and I had one boil off the acid in a battery I had forgotten was on the HB charger one winter.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
