Author Topic: Tapered crankshaft adapter  (Read 2682 times)
Offline TOMB
« on: May 14, 2016, 08:35:47 AM »
This is used to adapt the belt drive generator (eldo ) straight crankshaft  to a T3/ convert engine tapered shaft in a eldo / ambo frame.
Where to buy -who makes etc.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline guzziownr
Re: Tapered crankshaft adapter
« Reply #1 on: May 14, 2016, 08:52:19 AM »
Mark at Moto Guzzi Classics sold me one...
(562) 986-0070
« Reply #2 on: May 14, 2016, 08:53:12 AM »
Mark @ Moto Guzzi Classics did have some, but may be sold out now. Same with Teo Lamers.
http://www.tlm.nl/webshop/en/adapter-crankshaft-t3-to-v7-130740601010-moto-guzzi
Check with Moto International.
I have one for my Ambovert project, thought of having it duplicated by a local machine shop.
Offline ccoli
  • What? Me Worry?
« Reply #3 on: May 14, 2016, 11:50:58 AM »
Will this adapter do anything for me if I want to use an 04EV hydraulic engine in an ambassador frame?  If so, then I would be interested.
Wisconsin MGNOC Rep
« Reply #4 on: May 14, 2016, 12:19:10 PM »
No, that engine has a long straight "nose" on the crankshaft, not tapered like earlier engines. The EV crank is very long forward of the timing sprocket and if you're planning to use an Eldo timing cover with a similar adapter, the tip of the crank would likely hit the belt cover. Just guessing here from eye-balling it. Your best bet might be to retain the EV timing cover and crank mounted alternator, then use adapters or modify the frame.
http://www.thisoldtractor.com/moto_guzzi_loopframe_brackets_to_mount_a_tonti_timing_cover_in_a_loop_frame.html
